I just completed building from this layout, so it's tested and verified, though I still need to box it up. I wanted to have all the pots on the board, as I hate loads of off-board wiring. This also means that the board is secured in place by the pots. It's pretty tight, and might test your soldering skills. I've built the Violet Ram's Head version, but it will work for all the transistor versions with a little thought. The layout was designed to fit sideways (Zvex style) in a 110x60x30 enclosure, without a battery - I don't use them. I added an extra pot 'Clip' which reduces the effect of the diodes in the first clipping stage, an example of diode warping, giving interesting variations. I originally had Si diodes in that stage, but I liked the effect better with Ge. And not a submini tube in sight! Enjoy!
