Author Topic: “Event Horizon” PT2399 Sequenced Delay Concept  (Read 16076 times)
jacobyjd
Re: “Event Horizon” PT2399 Sequenced Delay Concept
« Reply #40 on: December 23, 2010, 10:17:17 PM »
I already have an enclosure drilled for 12 pots...what's one more? :)
How difficult would it be to make some of the pots optional? The biggest issue would probably be space saving. Do you have an idea of what size enclosure you'd want to fit this into?
Taylor
  • Total likes: 68
  • The clean energy source of the future.
« Reply #41 on: December 23, 2010, 10:30:33 PM »
Right, the enclosure and pot configuration are all entangled. I mean, if this was just for me, I'd probably design it for a 1790NS. I'd either do it landscape orientation, with the 8 sequence pots in a row and the others in a second row, or else I'd do it portrait style with 3 pot rows.
But, I know people around here like their tiny boxes. I'm 6'1" or so, so to me the little 1590b Zvex kind of thing is too tiny to adjust or to stomp accurately. But that's me. I can say for absolute certain that 13 pots, even 9mm ones, will not fit in a single row across a 1590b. Which means that we can't use the horizontal mount 9mm pots like Zvex does - I'd have to design for vertical-style pots, and these are not as available in the 9mm size (though I think Small Bear is supposed to start carrying those). So it leads me towards the 16mm pc-mount pots.
I guess the decision is between 1590bb and 1790ns, and portrait vs. landscape. I could make any of those 4 setups fit.
As far as optional pots, probably one or some would be, but I'm not sure what people find the least useful out of those controls. The difficulty of making lots of things optional with these PCBs is that then it's more complicated to figure out what you're supposed to leave out for the configuration you want, and people end up leaving out parts they need for the pedal to work. I like o make things easy to build, both for the benefit of people building the boards, and to cut down on my email overload.
Doesn't Markeebee work in biometrics or something? I wonder if he knows off the top of his head the diameter of the average human finger...
« Last Edit: December 23, 2010, 10:35:50 PM by Taylor »
  • Total likes: 130
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
« Reply #42 on: December 24, 2010, 07:16:04 AM »
When I was mulling this over I was thinking a toggle for auto/manual advance, and manual advance momentary footswitch, a mode switch for 2/4/8 steps, and a manual reset momentary footswitch.
I even did a panel layout for it, for 1590BB, but on reflection a 1590JJ would be more suitable.
« Last Edit: December 24, 2010, 07:20:06 AM by frequencycentral »
Questo č il fiore del partigiano morto per la libertŕ!
« Reply #43 on: December 24, 2010, 07:29:01 AM »
I likes this :) carry on
cloudscapes
« Reply #44 on: December 24, 2010, 07:47:04 AM »
 :icon_cool:
{DIY blog}
{www.dronecloud.org}
jacobyjd
« Reply #45 on: December 24, 2010, 10:55:55 AM »
I have my sequencer controls in a circle, so board mounted pots are out for me. Planning it for a 1790 is probably for the best, given the number of features.
Skruffyhound
« Reply #46 on: December 26, 2010, 06:42:08 AM »
1790, all the pots. I'm no designer so only time, tweeking and mods will show me the pots I don't use. I may also be forced to use off board pots, simply because I have so many.
