**WARNING** - NOOB incoming...
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaargh (splat)
Allrite guys hows it going?
Got a few noobish questions to ask if that is OK?
1. I always thought electrons flowed from the negative of a battery (- charge means they flow from + to - ?) So that would mean that the power in this circuit would be coming from the ground? But many circuits have diodes in them on the way to the ground...
Please explain
2. Why do you put the pot right before the ground? Doesn't this make it so that the signal would not be affected between the input and output? Heck why are any of the resistors that go to the ground there?
3. What's the capacitor doing in series with the pot? Is this to preserve tonal quality of some kind? How does it do this?
4. When you tell me you can't answer 2 / 3, what book should I get to explain it? I am interested in how exactly these circuits do what they do (please don't say magic)
5. Did you guys learn this by reading or just experimenting like crazy?
6. If I'm going down the mega experiment route, is the maplin GCSE started pack + some pots + input / output + a 3pdt what I will need to get going?
Thanks a lot,
Rob
