Author Topic: 2: The Schematic and parts list  (Read 340017 times)
aron
« on: September 25, 2003, 01:39:46 AM »
Given this:
Can you tell me how many capacitors, transistors & resistors there are in this circuit? Are there any more parts you need?
Joe Bonner
Hey,no one said anything about a quiz................
« Reply #1 on: September 25, 2003, 09:18:02 AM »
:lol:
Here's my analysis:
Parts from schematic:
5 resistors (2x10K, 2x100K, 47K)
1 transistor (NPN)
1 5k potentiometer
1 capacitor
3 electrolytic capacitors (.1uF, 10uF, 47uF)
Other parts:
Switch (DPDT?)
jacks (one stereo, one mono)
connecting wire
enclosure
9V battery snap
perfboard
Did I miss anything?
Joe
Chris R
Re: Hey,no one said anything about a quiz................
« Reply #2 on: September 25, 2003, 09:27:39 AM »
Quote from: Joe Bonner
Looks like the Electrolytic's should be 10uF, 22uF, and 47uF.
The .1uF cap is non polarized.
C
Andy
« Reply #3 on: September 25, 2003, 11:11:20 AM »
1 9V Battery
Resistors
100K - 2
47K
10K - 2
5K pot (linear)
Caps
47 uF
.1uF
10uF
22uF
Transistor
NPN (2N3904?)
Andy
Gus
« Reply #4 on: September 25, 2003, 11:58:13 AM »
The schematic looks nice.  It looks like it might help people that have problems with my hand drawn ones.  Also you can build it with pnps reverse the caps and PS like with FF circuits.
Gus
aron
« Reply #5 on: September 25, 2003, 06:57:29 PM »
Very good!
One .1uF (Film if possible)
Three Electrolytics 10uF, 22uF and 47uF
Two 10K resistors
One 47K resistor
Two 100K resistors
One NPN transistor 2N5088, 2N2222 etc....
One 5K linear pot.
Yes, you need a stereo input jack, mono output jack, perfboard, box and switch. In addition, either a transistor socket or DIP8 IC socket (easily found).
The box and switch can be omitted for our project since you can run this circuit right off of the perfboard and jacks if you want.
You also need 4 pieces of hookup wire and a battery snap.
aron
Can you tell me
« Reply #6 on: September 25, 2003, 07:12:22 PM »
how you might "wire" i.e. connect the components using the most minimum amount of hookup wire?
Do you see that one of the electrolytic capacitors can be mounted right on top of another device?
stratking
Re: Can you tell me
« Reply #7 on: September 26, 2003, 01:19:33 AM »
Quote from: aron
The only possibility I see for doing this would be to somehow connect the 0.1uF cap straight to the input jack.  Is that correct?
stratking
aron
« Reply #8 on: September 26, 2003, 03:12:18 AM »
I was thinking that the 47uF can be mounted directly on the pot lugs.
As for the rest of the components on the perfboard, you use their leads to connect them together.
Yes, there's even a use for the 300 extra resistors of "wrong" values you may have bought. You can use them for their leads!
aron
Ground points
« Reply #9 on: September 26, 2003, 06:12:25 AM »
OK, let's "clean up" the schematic a little more.
Remember those ground points? They all connect together so:
aron
Let's look at some of the components/parts you need
« Reply #10 on: September 26, 2003, 06:29:00 AM »
Here's a film cap:
an electrolytic capacitor:
a resistor:
a transistor:
8 pin DIP socket:
a potentiometer (front, then back)
a stereo Jack:
a mono jack:
wire:
Finally, the collection of components:
stratking
« Reply #11 on: September 26, 2003, 11:25:38 AM »
Quote from: aron
That makes a lot more sense, thats what I get for looking at the schem. when I'm busy.
stratking
Cliff
9 vdc power supply
« Reply #12 on: September 27, 2003, 09:28:59 PM »
Aron - First off, I want to express my gratitude for the time and effort you are putting in this project.  This is very cool.  Your willingness to share your knowledge is pretty amazing.  Of course, I'm just buttering you up for the first time I ask a dumb ass question. :D
As I intend to build this boost and then use it, it would be beneficial to me to have a 9 vdc Boss type input so that I can run it off a power supply rather than battery.  What do you think about including that in the schematic?  Anyone else?
aron
« Reply #13 on: September 28, 2003, 05:09:21 AM »
We can do that, but there's a really easy way to add a DC jack. Simply add another battery snap in the box to the DC jack. Yep, that simple. We can also investigate putting in a protection diode.
Mike Nichting
« Reply #14 on: September 28, 2003, 05:10:17 PM »
I would love to learn about adding DC jacks and especially the protection doide~!!
 BTW- i don't understand what you meant about the extra battery snap for the DC jack?? Can you explain that a little more in depth so it can reach my little brain :-)
Also, I would like to have switches explained to me in a very thouroguh way. How they work, how they switch and where they switch and why they are hooked up like they are. The difference between the DPDT and 3PDT switches and how to use the extra poles.
I didn't mean to take away from the schematic building. I will keep an eye out for those topics :-)
thanks
Mike N.
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
BD13UK
« Reply #15 on: September 29, 2003, 07:21:28 AM »
http://www.generalguitargadgets.com/v2/diagrams/pjsnap.gif
I think Aron may be refering to the above method, mind you I'm only guessing at this.
Brian
Cliff
Layout for project
« Reply #16 on: October 01, 2003, 08:42:18 PM »
Aron - I'm probably being ignorant, but I kind of expected the next step to be the development of a layout based upon your schematic.  Is this something you usually do before building?  I'm guessing that this circuit is so basic that you're skipping this step.
Second question:  On the parts list you indicated that we should purchase: "One NPN transistor 2N5088, 2N2222..."  My question is this: Which one?  Aren't these different?  Wouldn't a different transistor have a different affect upon the function of the box?
Me lame....I haven't made a parts order yet, so I can't participate on Sunday, but I'll be watching....
aron
Re: Layout for project
« Reply #17 on: October 01, 2003, 11:11:33 PM »
Quote from: Cliff
Nope, a layout is coming.
I draw a layout on my sketch tablet and then follow that when building onto perfboard.
Code: [Select]
There will be slight differences mainly when turning the pedal all the way up. Basically you can use any of these small signal transistors NPN no problem. Gus designed the circuit so it's not dependent on the transistor make.
Don't worry, the whole idea is really to have it online for reference.
Thanks for the good questions!
aron
« Reply #18 on: October 02, 2003, 02:54:51 AM »
What I usually do is sketch the schematic and a simple layout in my artist sketch book.
Like this:
Then I build right on top of the paper.
This way I can reference the schematic (which is right underneath) on the book.
This way I can jot down notes etc... right on the book.
I list 3 different ways of placing the components on the perfboard:
1: easiest
2: same except for the slightly tricky "jump" over the input wire.
3: minimal space layout. I usually do it this way with the components sticking up vertically off the board.
I like to put a sketch of the transistor and the pinout on the paper so I don't have to look for the datasheet.
BTW: the layouts I draw are as if you could see through the board - through the bottom.
re:
How to handwire on perfboard
Cliff
Questions
« Reply #19 on: October 03, 2003, 06:10:25 AM »
Aron - I don't know why I didn't flash on this before, but how come no stomp switch and led?  Would these be easy to add to the schematic and layout?
Also, which box are you using to house this project?
Thanks much.
