Author Topic: It's possible to wire 3 Big Muffs in a single box using only 3 pots?  (Read 8337 times)
Ben N
  • Total likes: 427
  • Ben N. - really! Now Israel, once Baltimore
Re: It's possible to wire 3 Big Muffs in a single box using only 3 pots?
« Reply #20 on: May 18, 2009, 04:20:43 PM »
Do the differences in the input stage actually matter sonically (other than the input/coupling caps)? I mean, it's a simple booster, and whatever distortions are taking place in that stage are getting swamped downstream. If not, why not share the input stage and sustain pot, and do your switching after that. Same question for the recovery. Seems to me that the sonically significant differences are mainly in the two clipping stages (transistors, source resistors, diodes & coupling caps) and the tone stack, so that's where you would have your redundant circuits and switching. Maybe put them on daughter boards that plug into end-connectors so you can fool around with it.
ninjaaron
« Reply #21 on: May 19, 2009, 01:36:55 AM »
I can't believe nobody has suggested relays yet. ???
You could wire up a cheap(ish) SP3T switch to turn power on or off as many relays as you like.
This seems like the obvious way to go, from my perspective.
gigimarga
« Reply #22 on: May 19, 2009, 11:09:03 AM »
I thought about this, but i found too much differences between the stages, and, let's say, i want the original sound as much as possible...thx a lot anyway for your suggestion!
gigimarga
« Reply #23 on: May 19, 2009, 11:13:05 AM »
Thx for your answer too...i thought about relays, but i think i don't have enough space in the box.
ninjaaron
« Reply #24 on: May 19, 2009, 04:28:30 PM »
Mouser has 'Omron GK6 Series: Ultra Small 1A DPDT Low Signal relays' You can get them PCB mount, and they are like 10x6.5x5.2mm
Really, mouser has a lot of tiny relays. I'm kinda in awe at the price some people pay for a single switch that does nothing more than what an SP switch and a couple cheap relays would.
Frantone was hip to this, and incorperated relay based switching into several of her designs, I belive.
Relays will probably eat batteries pretty fast, but who's using batteries these days anyway?
Ben N
  • Total likes: 427
« Reply #25 on: May 19, 2009, 10:01:29 PM »
Some of the new Way Huge/Dunlop pedals have relay switching.
gigimarga
« Reply #26 on: May 20, 2009, 01:21:39 AM »
MEEE...when i'm playing at home i am enough lazy to use batteries... ::)
