Camera Flash Power Supply Test
Started by Arn C., September 25, 2003, 10:24:07 AM
amz-fx
Here is the flash board after I've prepared it for use as a tube power supply.  I have removed the green insulation on the two tracks from the high voltage filter capacitor, drilled holes in the board and tinned around them.
The battery brackets are removed and I have indicated where to connect the plus and minus ends of the battery or power supply.
At the center of the board, I have peeled off the flex switch, which seemed to be mounted only with sticky tape and soldered a short jumper across the contacts so the power supply will run continuously.
regards, Jack
