I'm very excited to get this beast working!
I used the vero layout found here:
http://www.diystompboxes.com/smfforum/index.php?topic=74247.0Initial fire up gave me all three leds. All four lfo controls have a visible effect on the led indicator. So far, so good right? However, when the modulation toggle is engaged, the led stops flashing. That can't be good.The tremolo switch does not have this effect.
I decided to hook up a guitar and see if anything was working. The booster works, but that's about it.
Back to the bench. I fed a signal into the circuit and followed it with the scope. The signal is present at the junction of C19 and R14, but not on the other side of R14. I suppose I'm looking for a short somewhere around this area? I'll check that more after I clear my head.
Time to check the voltages, and the first thing I notice is that my 4.5v is actually about 4v. The two 47k resistors are from the same batch and are supposedly 1% metal film. They do look a little chinsey compared to other resistors I have. Would the cap have any effect on the voltage divider? This doesn't seem to affect the opamp too much since it seems to be doing it's job (signal is boosted). Could this be preventing the fet from working correctly? It seems that if the fet were working I would at least have tremelo.
Here is the entire list of voltages:
IC 1 (buffer/booster):
1. 4v
2. 4v
3. 4v
4. 0
5. 4v
6. 4v
7. 4v
8. 9.5v
IC2 (PT2399):
1. 5.1v
2. 2.56v
3. 0
4. 0
5. 3.5v
6. 2.6v
7. 4.7v
8. 4.7v
9. 4.9v
10. .374v
11. .385v
12. 4.8v
13. 2.9v
14. .115v
15. 5v
16. .115v
IC3 (lfo):
1. fluctuating
2. fluc.
3. flur.
4. 0
5. fluc.
6. fluc.
7. fluc.
8. 9.5v
FET:
G .637v
S 0
D .003v
Thanks for the awesome circuit Nathan! And thanks for the vero layout Lars!
