I am still having issues with my Mistress. Here are some of my observations on my build so that you can easily help me figure out the problem.
1 ) My initial suspicion is its not the LFO. On higher speed settings the ticking goes away. But I did not discount the possibility that it may still be the LFO.
2 ) I am using a regulated and well-filtered power supply to power my builds. My BSIAB2 and my Dr. Boogey are quiet when I power them with it.
3 ) Replaced C1 with 1000uF and nothing happened. My Phaseur Fleur kept its ticking into tolerable levels after installing a big cap to the rails. So I was surprised by the result with what happened to my EM. So I went straight to isolating the LFO and did not bother to change C2 and C3 anymore as advised to lower clock noise on its schem.
4 ) Lifted R29 from its V+ terminal and replaced it with one terminal of 47Ohm. I joined the remaining resistor terminals together and added the positive side of a 22uF electrolytic capacitor. The negative side of the 22uF goes to ground. Ticking is still present.
5 ) Temporarily removed the MN3007 from its daughterboard and ticking is not present. "Dry" signal is clean at the output.
6 ) Audio probed input and output terminals of Ic2. Ticking is only present at pin 6 and 7. Loud ticking also is present at pin 3 of MN3007.
7 ) On certain settings, the ticking goes away when Speed is changed. Ticking goes away too sometimes when Range and clock bias are fiddled. So the Speed, Range and clock bias have an of influence to the ticking.
8 ) No ticking at all on Filter Matrix mode regardless of the settings of the knobs.
9 ) Below is a sample soundclip of my EM. First and second samples shows the ticking. I was tweaking the range knob before going on to record the second sample. You will notice that the ticking slowed down a bit compared to the first. The third sample is set at higher speed and with no ticking present.
http://dl.dropbox.com/u/6983360/EM2.mp3Any ideas? Thanks in advance!
