I have an issue, I can not figure out. This is a single volume version, I have used this PCB in my other ones, so I know its good layout. I have replaced everything in the Power Supply but the Inductor and the 4.7 350V capacitor.
Symptoms..
If I run this at 120 volts all is good, just quite..
Runs at above 120V (I like the head room and volume of 180 volts) I get oscillation if I turn the volume up more than 1/4. I have tried putting a 500K resistor in series with the volume pot, but does not make a difference.
the only change is one the 6112 second stage where I used a 87K plate.
I am wondering if that plate resistor could be the problem.. or could it be the volume pot wiring?
I used my phone, I start @120v and then move up, I turn down the volume until there is no oscillation.
I am using the 3" speaker.. as my son moves the camera the sound changes.. that is not the issue
