Author Topic: waveshapers/wavefolders for guitar in 2009?  (Read 4686 times)
loss1234
« on: August 12, 2009, 12:35:28 PM »
waveshaping.
something i work with a lot for synths but for guitar it seems like there is very little information on making it work.
the first thing i am wondering if anyone has done any DIY guitar waveshapers in the last few years. the only one i have seen mentioned is TIM's triple fuzz and
that was mentioned in an OLD thread.
i have heard people say you could take a guitar signal and compress it first so that it would work,etc.
the reason i am asking this is this seems to be an untapped area of guitar fx.
any advice, articles, links,etc appreciated.
i would really like to get some new sounds going!!!
Re: waveshapers/wavefolders for guitar in 2009?
« Reply #1 on: August 12, 2009, 01:17:35 PM »
waveshaping.
That's largely because synth waveshapers/folders are in essence, analog computation devices.  It is easy to say what a synth waveform looks like - after all, you generated it. And synth waveforms tend to be either 5v or 10V in size.
On the other hand, it's sometimes difficult to say what a guitar waveform is. It can be quite small, 20-50mV for some older pickups, up to a couple of volts for modern humbuckers. And it already varies hugely when you get it to start processing on it - the ADSR is already part of the signal, as is the varying harmonic content of the string as it decays.  This tends to put waveshaping with a guitar signal firmly in the range of computing with an unknown. It can be done, but it's much more difficult.
On the other hand...
the first thing i am wondering if anyone has done any DIY guitar waveshapers in the last few years. the only one i have seen mentioned is TIM's triple fuzz and that was mentioned in an OLD thread.
DIY guitar waveshapers are the single most used devices - they're called "distortion" and "overdrive".  Admittedly, this is much duller, being primarily limiting and clipping, than complex wavefolders, but waveshaping is what's going on.
Yep. That's an attempt to get around the low and varying amplitudes of the guitar signal. Compressing gets you a more consistent signal to work with, and then amplifying gets it up in to a voltage range where the thresholds of the typical wavefolder/shaper can work on it. This raises the issue of somehow re-impressing dynamics back onto the signal after you're done shaping it. The only pedals I'm aware of that have addressed this is Craig Anderton's "Roctave Divider" and the E&MM Harmony Generator, both of which take the original envelope dynamics and re-impress a highly-compressed output with them. Guitarists in general tend to want some compression, anyway.
It is - but that's because it's both technically and user-interface-ed-ly difficulty. It's not nearly so immediately gratifying as making Yet Another Tube Screamer Clone (YATSC)  and going into business, raising a buzz by announcing a six-month waiting list.  :icon_lol:
The only wavefolder-style effect I'm aware of is the Hyper-Fuzz project, which I think Mark Hammer has on his page, hammer.ampage.com. This uses a three-threshold folder set up to match guitar levels inside the effect.
I've messed with wavefolders on guitar, but they were always fussy enough to set up and enough of a special case sound effect that I never developed anything for public consumption.
Quick IQ Test: If anyone in a governmental position suspected that YOU had top-secret information on YOUR computer, how many minutes would you remain outside a jail cell?
« Reply #2 on: August 12, 2009, 01:21:51 PM »
I've played about with bits of Ken Stone's Wave Multiplier http://www.cgs.synth.net/modules/cgs29_wave_multiplier.html. Like R.G points out though these aren't designed for guitar signals and probably don't work properly with them.
The grinder section is interesting with guitar, gives a strange ringing distortion. I think I changed a few component values, to make it wilder, can't remember exactly what now though.
The bottom bit of the multiplier with the diodes and opamps makes a crazy octave up fuzz.
The Lockhart folder is cool as well, that's basically what the triple fuzz is.
« Reply #3 on: August 12, 2009, 05:55:34 PM »
The Simple Squarewave Shaper at Circuit Snippets (currently offline) is an adaptation of  project/circuit that originally appeared in POLYPHONY.   It is essentially a comparator that produces a square wave, which is then followed by a variable lag circuit for rising and falling edges.  This lets you produce ramp, sawtooth, and triangle waveforms as well as the original square.
I have a waveshaper module that was part of the Korg PME40 series from the early 80s.  It was a fairly complex circuit for what was essentially a fuzz. http://reviews.harmony-central.com/reviews/Effects/product/Korg/PME-40X/10/2
Boss makes a "wave processor" dual pedal (WP-20G) which appears to be clearance bin material in some stores. http://www.rolandus.com/products/productdetails.php?ProductId=166  It is actually a synth that requires a GK-series divided pickup to work.
Processaurus
« Reply #4 on: August 13, 2009, 06:57:03 PM »
I adapted Juergan Haible's Wave Multiplier B for stompbox use a few years ago, using a max 1044 for the bipolar supply, and an opamp boost and soft clipping stage before it to make it work with a guitar.  It's a really unique distortion pedal.
http://www.jhaible.de/jh_wavefolder.html
Some bit crushers that do bit swapping like the frostwave sonic alienator are doing the same thing as wave folding.  Also the plastic and unusual Soundblox Multiwave distortion pedal that came out recently does wave folding.
Chrome Dinette
« Reply #5 on: August 30, 2009, 08:38:36 PM »
So, I signed up on this forum a while ago and promptly forgot about it.  Then, recently, I built a guitar adapted version of one of the wave folders on the CGS website.  I was wondering if anyone else had done anything similar and this thread turned up on Google.
Here is a Youtube clip of the pedal I built:
http://www.youtube.com/watch?v=l4LTEaIYmU0
The wave folder section is preceded by a jfet mu amp, with a cap that can be switched across its output pot to cut some high end.  I put a 10k linear pot between the triangle and square wave sections and ran that into a 10k audio pot for output level.
« Reply #6 on: August 31, 2009, 09:36:26 AM »
The person you really want to speak to is Anthonie "Ton" Barmentloo.  You cansee many of his experiments here:  http://www.youtube.com/user/puretubetechno
The, um, ones that do not have an oscilloscope in them generally have to do with beer, and not electronics.
chemosis
« Reply #7 on: January 17, 2019, 08:57:30 PM »
im confused. I thought Crowther audio prunes and custard was a wavefolder style distortion. I thought tim escobedos Bronx cheer is a wavefolder. I thought synthmongers fuzzmonger is a wavefolder distortion??????
chemosis
« Reply #8 on: January 17, 2019, 09:01:13 PM »
and you have to treat these circuits lie you treat Octavia or octave up by rolling back tone and possibly even volume a slight bit then play above the 9th fret. that's were the magic is with wavefolder type circuits with guitar like prunes and custard
noisette
« Reply #9 on: January 18, 2019, 05:12:11 AM »
Yes, they are. A synth uses a VCA in front to vary folding "order". A guitar player achieves it with playing sensitivity.
The signal changes direction not only at highest and lowest level, but at different breakpoints above and below zero...
Prunes and custard is one of the best pedals I have ever heard and played, it is like a different kind of guitar synth, no, really, so much tonal variation. Get one! (@everyone)
Or build one :-X
Bronx cheer and Wave Tripler (?) are also nice, not so variable though, but easy to build in an hour. Bronx cheer is interesting in that it also introduces frequency dependance.
I donīt know synthmongers...
The tone god has also switch blade iirc. Sounded good on breadboard!
« Last Edit: January 18, 2019, 05:16:39 AM by noisette »
"I don't like jail, they got the wrong kind of bars in there..."
Bukowski
snk
« Reply #10 on: January 18, 2019, 01:26:03 PM »
Tone God Blade, or Rothwell Switchblade :icon_biggrin:
noisette
« Reply #11 on: January 18, 2019, 04:58:45 PM »
 :D
I meant the first...
Forget to say Prunes and Custard is especially killer on bass guitar.
Play two adjacent notes that beat against each other (like f# and g), try the upper registers, compare against deep registers, sounds of bizarre beauty---
/enthusiasm off
Bukowski
snk
« Reply #12 on: February 19, 2019, 03:54:13 PM »
I built the Prunes and Custard, and i am indeed enjoying it  ;D
chemosis
« Reply #13 on: March 07, 2019, 10:03:17 PM »
Or build one :-X
   i have had many prunes and custards and love them esp when treating them like a Octavia.such a warm smooth tone at certain settings. i like Bronx cheer alot to. if the maleeko chaos isn't a wavefolder circuit it definetly sounds like one. if you haven't heard one checkout malekkos official video of the chaos because the downer just dosent sound as good to my ears. malekko chaos! sounds different than P&C but still amazing
ashcat_lt
« Reply #14 on: March 08, 2019, 01:07:04 PM »
This is an old thread and idk why we're talking about prunes but...
I've been working on a thing in a digital format that extracts the RMS value of the input signal and uses that to set the clipping threshold after the gain stage.  With certain shortish window times it works really well to keep the signal distorted by about the same amount no matter how loud or soft you play while mostly retaining the overall dynamics of the input.  It's kind of unnatural but also kind of really cool, and something a lot of people have been hunting for a while.  With somewhat longer window times, it does a kind of interesting subtle blooming kind of thing.  At times up around a second, it turns into a special effect, but a fairly interesting one.
Somebody smarter than me would have to figure out how to do that in analog, though honestly I don't think it has to be that tough.
highwater
« Reply #15 on: March 08, 2019, 10:39:07 PM »
Run clipping diodes to the output of an envelope follower instead of to ground (you'd need to run each diode to a different voltage, and place them before the coupling cap from the opamp).
OR
NE570/571. Compress, distort, expand.
The latter would probably be easier (or at-least less parts), the former would probably be closer to what you're doing digitally.
"I had an unfortunate combination of a very high-end medium-size system, with a "low price" phono preamp (external; this was the decade when phono was obsolete)."
 - PRR
ashcat_lt
« Reply #16 on: March 09, 2019, 03:00:07 PM »
I've done compress distort expand and it didn't really work out as well.  That might have been my fault.  Diode biasing was what I kind of thought, and IS pretty much what I'm doing in code.
