OT Pictures!
Started by JKowalski, August 18, 2009, 01:35:58 PM
nexekho
I made the transistor angry.
nexekho
Now all it needs is... well, frankly, the CPU that actually does anything.
Nikolay
Hi, guys. I finish my new simple custom looper
Here is a shot:
Niki
tasos
Quote from: Nikolay on January 07, 2012, 06:47:38 AM
Here is a shot:
Niki
Great!
So how do you make sure all the labeling is in place(not in axis)
@james: come on...give us a clue you teaser.. ;D
nexekho
Quote from: deadastronaut on January 07, 2012, 11:19:53 AM
Ha!   ;D
It's just a microcontroller board; a little 5532 preamp to the ADC, ATMega328P, two 8-bit PWM ports with a resistor divider to get a rough 16 bits, a 5532 buffer, a Chebyshef lowpass to filter the PWM to something audible, a 5532 post amp, then output!  One op amp is spare and might be used for buffering a CV or expression jack further down the road.  Other than that, a 4017 hooked up to a 7-segment display and two LEDs sinking current into one of the microcontroller pins and some buttons for input.  Just was a bit inconventient to need both an input and output buffer to use the Arduino.
 ;D you liost me on the first sentence....lol....i knew i shouldn't of asked.  ::)
artifus
Quote from: Earthscum on December 23, 2011, 09:13:56 PM... I've found myself paying attention to what the stage feels like, especially when I wear shoes with thinner soles.
i've noticed a few barefoot bassists, particularly in the jazz world.
a soBer Newt
My first baked PCB, came out way better then I thought it was going to, rather proud of my self. Less than six months ago did not know how to do SMT and now look at me!
a soBer Newt
Quote from: tasos on January 12, 2012, 01:40:39 PM
What are you making?
Its a mic pre that AEA makes, the RPQ 500, I am there intern so I am learning about small run SMT prototyping.
Earthscum
This made me laugh...
(Don't really do this)
tubelectron
Quote from: Earthscum on February 06, 2012, 11:57:16 PM
DO NOT DO THIS - the battery has all the chances to explode !!!
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
tubelectron
... And, oh, I was heavily into restoring vintage tube VTVMs these short and recent times :
OK - Big contrast : that's not SS, SMD nor microcontroller device, but somewhere musical-maintenance-tubes related...
A+!
Seljer
I want to share this somewhere. I made a phono preamp and bipolar power supply. The rotary switch gives you three different gain settings (+30,+40,+50dB), I still need to find a knob somewhere.
This finally enables me to listen to all my dad's cheesy records  ;D
And the turntable I'm using it with, a lovely 1970s Technics. Had to spray a little bit of contact cleaner into the speed adjustment potentiometers and it now spins without any trouble.
tasos
Hey could you tell us more about the phono preamp? ;D
Seljer
Quote from: tasos on February 11, 2012, 06:49:35 PM
No problem! :) I followed the schematic from dano's site http://beavishifi.com/articles/phono-preamps/ . The RJM Audio one to be specific, I used the 'more accurate' component values for RIAA eq curve in the feedback loop as listed on the original page (http://phonoclone.com/diy-pho5.html). No audiophile parts, an NE5532 opamp, just regular film caps all round (paralllel with a bipolar electrolytic on the output) and whatever resistors I got in the right values. Sounds fine, no clipping with the +-9V power supply (I probably could have done+-12V with the transformer putting out way more at so little load but I purchased 9v linear regulators so I'm stuck with that for now), very little noise from the preamp itself. If I dime everything you I get some some 50hz hum but I think thats coming from the actual turntable...and then theres the continous battle with dust and such on the actual records.
I have an eagle layout if anyone wants to try making it (I built it on perfboard but I used the program to get the basic layout done).
tasos
Hmmm thanks...
I am interested because i am making a bass head and when i connect my bass directly to the power amp it is very quiet(the power amp is 200watt)
However when i connect my bass in any of my mixers(i have two) and then to the power amp the sound from the speakers is LOUD!
Do you think a phono preamp would do the job?
My power amp is http://sites.google.com/site/quasisdiyaudiosite/nmos-series/nmos200-1 to220 version...
Any help would be really appreciated
Seljer
Quote from: tasos on February 12, 2012, 06:18:09 AM
Hmmm thanks...
The phono preamp's purpose is other than boosting the millivolt signal from the record player is to apply a special EQ curve (records are manufactured with a treble boost which is then removed when you play them and in doing so, you avoid high frequency noise http://en.wikipedia.org/wiki/RIAA_EQ). So...it's a one trick pony for this specific purpose (hooking up the turntable to the computer to digitize some records).
But a simple opamp gain stage would work fine for what you need to do (go find the schematic for the MXR Microamp or just read up on operational amplifiers :) ) ...there are a couple of designs for dedicated bass preamps out there too (with extra tone controls and such).
egasimus
Tasos, check out some JFET bass preams, e.g. Albert Kreuzer's.
http://www.albertkreuzer.com/preamp_onboard.htm
