Hi guys, having a bit of a problem with this boost circuit. I'm getting attenuation instead of a boost, but hey at least the pot does something, thats better than my fuzz face attempt!! I've hunted through the circuit many a time now and found a couple of problems (the 10k and 100k going up to 9v were the wrong way round). Im now 99% sure its built as shown in the schem, and i've used the wiring picture provided but omitted the led part. I've gone through and checked all the voltages and all are correct apart from the collector voltage which is only 4.5v this goes up to 8.8v when the transistor is removed. I've double checked the resistor value between the C and 9v and its 10k (measureing 7.9k in situ).
Now this thing might be an associated problem or maybe not even a problem at all... I originally built it using a blue 0.1 uf resin dipped ceramic monores
cap as the input cap, but after finding about 3v on the input (before cap) and 1.5v on the output (after cap) I swapped it for a green film one as suggested, this brought he voltage down to 1.2v and 0.8v but just now as ive tested it it seems they discharge as i hold my meterleads on so guessing this is nothing?
Could it be anything to do with my pickups being 2 big humbuckers on a balance pot set up?? turning the tone on my guitar down also makes a heart beat type sound when the circuits running. This reduces slightly if i use a 2n2222 instead of the 2n3904.
Sorry I know I've waffled on a bit but tried to include everything I've found. any help would be greatly appreciated.
Thanks Tom
