DIY eBow
Started by Guitarfreak, December 01, 2009, 11:15:32 AM
Paul Marossy
A small Altoid tin seems very convenient for an enclosure, but I don't know that a metal enclosure would work - if it has any steel in it. I think it would interfere with the proper operation of the circuit.
Taylor
Another similar thing that's fun to build is this: Take a DC vibrator motor:
http://www.allelectronics.com/mas_assets/image_cache/height.500_width.500_modified.1238617442.5975.DCM-344.jpg
and attach it to a 9v battery. I made one when I was 16 and called it the "V-bow". The little metal weight spins around many times a second and whacks the string. The sound is halfway between very good tremolo picking and an ebow. Total cost: $5. Time commitment: 20 minutes maybe. A speed knob can be easily added with a pot as a voltage divider.
You can get these motors from Playstation controllers, pagers/cell phones, or ask your girlfriend if you can cannibalize her unused marital aids.
snufkin
http://www.youtube.com/watch?v=UkQhRFS6sRM
pc speakers can be used as the coils
making this project a hell of allot simpler
easyface,phase 90,many fuzz faces,feedback looper,tremulus lune and so on soon to be ADA!
Wasted_Bassist
Quote from: Taylor on December 02, 2009, 03:19:27 PM
I tried to make something similar. The problem i encountered was that whenever the motor got too close to the pickup it made a loud screeching noise from picking up the movements inside the motor.
Taylor
Yep, that can be a problem. I didn't have much trouble with it on my P-bass, because there's so much area without pickups underneath, but for guitarists with 3 pickups in a smaller space (strat) it might be tough to find a sweet spot. Shouldn't be too much of a problem for you, Wasted Bassist:icon_wink:
Top Top
Quote from: snufkin on December 02, 2009, 03:43:36 PM
Any idea where you can get those PC speakers new?
Jarno
Two pages, and nobody wants to build moog-like guitar electronics?  :icon_mrgreen:
That thing is so incredibly cool. It shouldn't be too hard, just build a e-bow in every pickup.......for every string  :)
Taylor
Well, I do have some far-off plans to make a Moog bass. I was going to wind 2 individual pickups for each string and do the usual amplification and feedback. The fancier features like the intelligent mute/sustain would be pretty difficult in analog, but doable digitally. You need to adjust the phase of the feedback signal in proportion to the input volume per string, I think.
Paul Marossy
Quote from: Jarno on December 02, 2009, 05:05:34 PM
That's basically a Sustainiac pickup.  :icon_wink:
Taylor
#29
Actually, no. I have a Sustainiac in my bass, and while it's very fun, it only will sustain one or 2 notes simultaneously. (I know you're wondering why a bass player wants to sustain 4 notes at a time, but...I just do)
Doing something like the Moog requires a separate pickup, feedback amp, and driver for each string to allow for full autonomy. Also, having each string separate lets you do different processing for each note. Lower notes may need some compression and lowpass filtering to sustain well, whereas high strings need more gain, etc.
Top Top
Quote from: Taylor on December 02, 2009, 07:11:00 PM
Could the type of sensor used in the DIY ebow video linked above (the PC speakers) be used as individual pickups on a guitar? Or do they only work in the case of the ebow where they aren't actually performing a regular audio function?
Paul Marossy
Yeah, I guess you're right on that. The original 1978 ebow patent had a version where each string had its own sustainer. I think part of the Moog idea might actually be closer to that conceptually.
Taylor
Quote from: Top Top on December 02, 2009, 04:43:57 PM
Quote from: Top Top on December 02, 2009, 07:42:16 PMCould the type of sensor used in the DIY ebow video linked above (the PC speakers) be used as individual pickups on a guitar? Or do they only work in the case of the ebow where they aren't actually performing a regular audio function?
Typing "magnetic buzzer" into Mouser's search brought up a bunch of transducers that look identical to the one in that video. About $1.50 each. If you follow his instructions about the relative impedances you should be good.
As for using them as your guitar's actual pickups, I have no idea. Since guitarists often swap out tons of different expensive pickups in search of "their sound" it's unlikely that a coupole of $1.50 coils are going to sound great. However, there's no rule that your sensor and your output pickup have to be the same. You could just equip your guitar with an actual guitar pickup in addition to the coils.
One tip, though: audible pickups need to be some distance away from the driver coils, or you will get squealing. At least a few inches.
I'd love to see some people make this happen. It's one of those projects I don't know if I'll ever get to.
Top Top
Quote from: Taylor on December 03, 2009, 01:39:45 AM
Thanks for that... I actually saw those buzzers on mouser and Jameco, but I wasn't 100% sure they were actually the same. I am a little ignorant on my transducers...
though honestly, I don't plan to build an ebow per-say... (see sympathetic reverb thread ;) ), but actually, maybe I would, given how simple it looks... with those components and the circuit mentioned earlier.
Jarno
Actually, no. I have a Sustainiac in my bass.....
8)
But I think most of the feature in the Moog guitar are feasible in analog. But indeed, you will need a separate driver for each string.
I assume they do the harmonics thing by either frequency multiplication of the input signal or perhaps use the input from the bridge pickup (which contains more higher harmonic content) to drive a coil in the neck pickup. That could be possible, I think.
Maybe I'll need to buy another Squier Bronco (I'm also a bassplayer myself) and turn it into a piccolo bass version :-) Less strings to drive :-)
Top Top
Quote from: Jarno on December 03, 2009, 03:45:46 AM
8)
To have a separate driver for each string, would you need a separate sensor and driving circuit as well, or could you just have several drivers wired in parallel to the output of the one 386 circuit?
Taylor
Having a single amp would make separate drivers pointless. The idea here is that if you feedback all the strings into all the strings, you end up with only 1 or 2 notes sustaining, because you're feeding the A string to the G string, and the G to the A, etc. which doesn't create any sustain. To sustain all the strings simultaneously, you need to feedback each string only to itself.
So you need to preserve the separation all the way from the sensor to the amp to the driver.
Strategy
It took me forever to remember the name of this thing- Gizmotron:
http://www.suppertime.co.uk/blint/gizmo.shtml
A mu-tron related product. Schematic online somewhere who knows?!?
- Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
pazuzu
Quote from: Paul Marossy on December 02, 2009, 10:47:26 AM
yea i guess. my kid has some plastic cases that gum came in, but i couldn't find a picture online. maybe a chew tin?
space_ryerson
There's a guy on the project guitar forum working on a PIC based hexaphonic sustainer currently. Might be worth a look.
