Author Topic: LED questions  (Read 6053 times)
1tczx
LED questions
« on: December 09, 2009, 11:28:21 PM »
1) what is the maximum voltage my LED can take?
2) Why must there be a resistor in series of the LED in a circuit? can we do without one?
just some questions :D
1tczx
Re: LED questions
« Reply #1 on: December 09, 2009, 11:33:04 PM »
just one more question, should i put LED in parallel or series with circuit??
.Mike
Re: LED questions
« Reply #2 on: December 10, 2009, 12:39:35 AM »
1. You should probably be more concerned about current than voltage. Pretty much any LED you get is going to be able to handle pedal voltages, provided you use an appropriate current limiting resistor.
2. If you don't use a resistor, the full current of your power source passes through the LED, straight to ground. Not desirable.
3. Parallel.
Look here: http://led.linear1.org/why-do-i-need-a-resistor-with-an-led/
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
frank_p
Re: LED questions
« Reply #3 on: December 10, 2009, 01:04:10 AM »
1tczx
Re: LED questions
« Reply #4 on: December 10, 2009, 01:49:26 AM »
thanks again guys :D this forum is awesome. learning lots of stuff from here
lyndonguitar
Re: LED questions
« Reply #5 on: July 13, 2010, 05:22:08 AM »
learn a lot. thanks :)
guitar-china.com
chinese guitar manufacturer
KENNIGO
Re: LED questions
« Reply #6 on: July 20, 2010, 09:35:55 PM »
thanks those links are right what i needed
