Author Topic: [Tutorial] Making a Multicolor Etching!  (Read 69328 times)
Slade
Re: [Tutorial] Making a Multicolor Etching!
« Reply #20 on: December 17, 2009, 11:26:59 PM »
You're welcome! Glad you like it! ;)
markeebee
« Reply #21 on: December 18, 2009, 09:01:59 AM »
Thank you very much Fernando.  You are an artist, an engineer and a true gentleman!
KazooMan
The Third Time is the Charm
« Reply #22 on: December 18, 2009, 09:47:25 AM »
The third link worked just fine.  Very nice tutorial.  I need to work harder at masking off areas that don't get a good coating of toner.  The tips on sanding are also appreciated.  I have been using steel wool to prepare the surface and it doesn't always result in good adhesion of the toner.
Valoosj
« Reply #23 on: December 18, 2009, 11:04:07 AM »
¡Muchas gracias Fernando! Y no te preocupas de tu Inglés ;)
Ahora estoy pensando de un dibujo como los tuyos para un 'swell pedal' (el de Solderman) y un woolly mammoth. Sólo para probar tu técnica.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
Cap
« Reply #24 on: December 18, 2009, 12:02:29 PM »
Thanks for the tutorial!!!!  ;D ;D
now..i need new enclosures.. :D
  • Total likes: 130
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
« Reply #25 on: December 18, 2009, 01:23:34 PM »
Thanks for the tutorial Fernando, I'm downloading it as we speak. I yearn to produce etches like yours, it's one of my goals for next year.  :icon_cool:
EDIT: OK, just read the whole tutorial, you attention to detail is excellent. Your etches are so good that my mouth is literally watering. My GF thinks I'm odd for that.
« Last Edit: December 18, 2009, 01:38:56 PM by frequencycentral »
bancika
« Reply #26 on: December 18, 2009, 01:39:50 PM »
So cool, thanks for the tutorial
Hupla
« Reply #27 on: December 18, 2009, 05:42:11 PM »
Hey guys. Just want an opinion. Is it easy to etch an enclosure after you have drilled holes into it? I can imagine it isn't too different, I just want to know as I don't think ill be able to etch for a while but I want to get the pedal done soone.
Completed builds: BSIAB2
Pedals to build: Dr.Boogey, TS-808
Slade
« Reply #28 on: December 18, 2009, 05:49:42 PM »
You're welcome, guys, I'm so glad you like the tutorial!  :icon_biggrin:
I think the sanding is a very important part of the process. Much people doing their first time etching don't pay attention to this part.
Valoosj, gracias por hablar en español! Eres nativo, aprendiste o usaste un diccionario? Haha.
Rick, just give it a try. It's so infinite as what you can design. Some persons think this techniques are limited... Maybe the colors are a limitation, but not the designs.. Just look at InsaneKane beautiful reverse-etchings... Because of that I incentivate you all to innovate applying your own ideas in the tutorial ;)
You can do it by protecting the holes (after the hard sanding work) with masking tape. The difference is that you won't immerse the enclosure on the etchant, but you shed the etchant over the designs in drops very carefully, just protect the areas around the designs and all the parts of the enclosure that don't have designs.
« Last Edit: December 18, 2009, 05:51:25 PM by Slade »
Hupla
« Reply #29 on: December 18, 2009, 05:57:45 PM »
So it's not a good idea to immerse it in the etchant but you can still do it? im not familiar with the drip technique seems more awkward.
Valoosj
« Reply #30 on: December 18, 2009, 06:00:03 PM »
Vivo en Bélgica, un pequeño país que nadie conoce y necesitamos aprender lenguas. ¿Porque quién habla néerlandes?
Estudio Inglés y Español en el instituto superior de Amberes, y hablo un poco de francés y allemán.
Slade
« Reply #31 on: December 18, 2009, 07:56:13 PM »
I don't recommend doing the immersion in this case, I recommend to shed the etchant over the designs carefully ;).
Ok, estás escribiendo muy bien, falta escucharte hablar para evaluarte! Haha, sólo bromeo. Ni siquiera conocía el nombre de tu idioma, pero si he escuchado mucho de Bélgica ;) Yo intento dar a conocer Chile al mundo a través de mi trabajo, es una buena forma!
« Reply #32 on: December 18, 2009, 09:08:41 PM »
Great job on the tutorial Fernando, thnaks for sharing!
dave
Slade
« Reply #33 on: December 19, 2009, 11:48:07 AM »
You're welcome ;)
Thanks for your comment.
guitarman89
« Reply #34 on: December 19, 2009, 01:46:43 PM »
thanks for this tutorial! great work!
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
Hupla
« Reply #35 on: December 20, 2009, 10:42:16 AM »
So do ya let the etchant run over it or like let it puddle on the part you want to etch?
Slade
« Reply #36 on: December 20, 2009, 11:05:50 AM »
The second.
Just shed the etchant in drops over the designs until you cover them completely (You don't need to cover all the surface, just the designs, the surface must be protected with nail enamel and masking tape), then use a tip to remove the metal rests while the etchant is still working, like stirring it. Once the etchant is agglomerated just use a napskin to take off this rest, clean the enclosure with water and an old toothbrush and see if the etching is deep enough. Here I let you some pictures explaining this:
Hupla
« Reply #37 on: December 20, 2009, 11:14:48 AM »
The second.
Thanks very much. it makes alot of sense now.
Slade
« Reply #38 on: December 20, 2009, 03:25:45 PM »
You're welcome. I want to see the etchings you'll do in the future ;)
Hupla
« Reply #39 on: December 21, 2009, 01:14:48 PM »
I should have one in the next few weeks, and looks like i wont have to do the drip technique :)
Thanks so much for your tutorial.
