Hi,
I am trying to understand how a true bypass loop switch works. I have one from Radial Engineering called the Big Shot EFX. When one of the loops is selected but the receiving jack from the effects loop is left unconnected, I can hear a faint bleed-over from the input guitar signal. I don't understand why this happens if the design is true bypass. How does that guitar signal get passed through to the output?
For example, if I send my guitar signal through the loop into a tuner and do not send the signal back to the looper from the tuner, there is bleed-over of the guitar. It's also distorted.
I noticed that on Loop-Master's FAQ, he acknowledges that there is a faint bleed-over in his true bypass switches under the same condition. Again, can someone explain why?
Thanks very much!
Jason
