DIY Stompboxes > Building your own stompbox
typical phaser lfo waveforms?
daverdave:
Cheers for the replies, sounds interesting. I was using an opamp astable for the squarewave and then an intergrator to obtain a triangle wave from it, would it be possible to get a hyper triangle from this setup? I have both opamps biased at around 4.5v and the output of the squarewave through a voltage divider to get 2v pk-pk.
Mark Hammer:
Check out this old article. http://hammer.ampage.org/files/hypertriangleclock.gif
daverdave:
that's great, I'll have a try with that when I get back to uni.
daverdave:
Just out of interest, what should the output waveforms be biased at? Since they're roughly 2V pk-pk are they best being near 1V so that they swing bewteen 0 and 2V? I was going to use optocoupler to drive the stages.
MoltenVoltage:
Whatever you do, consider using rail to rail op amps to get the full sweep range. You will be surprised how much better it sounds.
We have a schematic posted for doing that with our MV-53 tap LFO chip on the Phase 90, but you can modify any LFO in a similar manner.
http://www.moltenvoltage.com/mv-53.html
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
