Author Topic: Bit Crusher  (Read 3915 times)
slotbot
Bit Crusher
« on: January 11, 2010, 07:30:34 PM »
I built this using an 8 bit PIC so i thought i would post it here :)
http://mtlasm.blogspot.com/2010/01/waking-up-on.html
« Last Edit: January 11, 2010, 07:33:25 PM by slotbot »
MoltenVoltage
Re: Bit Crusher
« Reply #1 on: January 11, 2010, 07:39:59 PM »
Sounds cool!  I've been working on a 16 bit one on and off for a while.
Is it a PWM output?
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
slotbot
Re: Bit Crusher
« Reply #2 on: January 11, 2010, 07:51:41 PM »
No i didnt use PWM out for this one. Just R2R ladder accross an 8 bit port. i figured it would be more fun that way for tweaking/experimenting.
cloudscapes
Re: Bit Crusher
« Reply #3 on: January 11, 2010, 08:48:45 PM »
hey Scott  :)
dropping random pins on an R2R is so fun! the harshest insanity fuzz you'll ever need!
listening to samples now. that thing sounds effin RUDE
dialup is nuts!
where do you get your push pots?
{DIY blog}
{www.dronecloud.org}
slotbot
Re: Bit Crusher
« Reply #4 on: January 11, 2010, 11:15:07 PM »
hey man :D
actually it is an encoder. i got them from ebay, its pretty swank because you can keep spinning it around continuously. a little less straightforward to interface but sort of fun. The rate knob is a pot though (less swank).
