Aron Smash Drive!! HELP!!
Started by 1tczx, January 14, 2010, 02:42:21 AM
1tczx
Building this currently
http://www.aronnelson.com/gallery/main.php/v/TheBigMan-Layouts/smashdrive.gif.html
however, it does not have a volume control..even with all pots down, when the efx is on, some signal will still pass thru.
anybody knows how to put a volume control pot??
ARon!! help.
humptydumpty
to the best of my knowledge, take the output wire, connect it to lug 3 of a 100k pot, connect lug 1 to ground, and lug 2 to the output jack
edit: someone correct me if im wrong
compuwade
You should be able to connect the output from the circuit to a 500ka pot and then to the output jack. That should give you a good volume control. Kinda like this one :)
http://www.aronnelson.com/gallery/main.php/v/Daves-Layouts/Smash_Drive.gif.html
1tczx
#3
lol it does not work humpty, no sound at all from efx. hiaz..
lol compuwade i cant really read the pcb..
edit* followed pcb. vol pot lug 1 to grd and mid lug 1? thats wad i see it.
still wun work
anchovie
For the "Killer" version: Remove any connection from Treble lug 2 to output. Connect Treble lug 2 to Volume lug 3, Volume lug 1 to ground. Volume lug 2 is output.
1tczx
lol thats wad i did bro.
as said by humpty. now not even a sound from it.
anchovie
Do you get sound back if you remove the wire from Volume lug 3 and take the output from there?
1tczx
yes before i added the volume pot there was sound. after that, totally disengaged. lol /
anchovie
That's not what I asked. Does the circuit work again if you take the volume pot off?
1tczx
ya it does. but once i connect to lug 3 agn it became silent. help still needed!!
anchovie
1tczx
the 2 pots u see are the tremble and volume pot. output was originally from tremble lug 2...
anchovie
You can ruin pots by soldering in those holes, that's not what they're for. Got a DMM so you can measure the volume pot resistance?
1tczx
haha its easier to solder in wires into holes :D volume pot working fine. all way down 0 ohms , all ways up 500k ohms
anchovie
OK, measure the resistance between volume lug 2 and the output jack (to check the yellow wire) and volume lug 2 to ground (with pot at max).
1tczx
lug 2 to output jack ok, 0ohms.
lug 2 to grd full 500kohms at max pot.
all working well...
anchovie
And just to confirm, 0 ohms between lugs 2 & 3 of the volume pot at max? If that's the case and you've got sound at the end of that wire coming from the treble pot, then hooking it up to volume lug 3 should, in theory, work. If it still doesn't then I'm stumped!
1tczx
err bro for ur last qn, there is no reading between lug2 and lug3 of volume at max...why..
humptydumpty
is it/was it connected like above? cuz im missing the whole treble and volume connection if it is
anchovie
Quote from: 1tczx on January 14, 2010, 11:26:53 AM
If it's open circuit between those two lugs then the pot is damaged and you won't get any sound at the output no matter where the control is set. Best replace it and not solder into those holes this time!
