Who did the Supa Sustain?
Started by Thomas P., August 21, 2003, 02:29:45 PM
Thomas P.
Did anyone build it? I would be really interessted in how it worked out.
Regards,
tomboy
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
petemoore59
Yes I tried to build a working Supa Suatain
  But No it didn't werl///dont be discouraged by my failures though
RickL
I built one that works. It was some time ago but IIRC I had to fiddle with the LED/LDR combo a bit to get it working. Try a high efficiency LED and an LDR that goes to a fairly low resistance.
Thomas P.
What transistors did you use? The schematic says BC169B but they're quite hard to find for me. I wonder if the ordinary 2N3904 etc. will work, too?
Regards,
tomboy
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
RickL
I don't remember exactly what transistors I used. Probably 2N3904. Most projects that use bipolar transistors will work with a variety of subs. They might not sound exactly the same as with the originals but they will work.
jsleep
I don't think there's anything particularly special about the BC169B, Small Bear does have them if you really one to use it.  The layout on my site is designed for the modern common transistor pin out like the 2N3904.
JD
For great Stompbox projects visit http://www.generalguitargadgets.com
Thomas P.
Well, ordering 4 trannies form small bear to europe seems a bit too much for me...I designed my layout for ordinary pinout, too :wink:
I will use sockets and try a few types and see what's best.
Thanks for the fast replies  :D
Regards,
tomboy
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
