Silonex NSL32SR3 pinout
Started by TheNixon, February 24, 2010, 02:34:40 PM
TheNixon
Hi,
can somebody confirm drawn pinout on attached picture for nls32sr3? I have some issues and now I am little bit confused about pinout.
Thanks.
GP
Datasheet here: http://datasheet.octopart.com/NSL-32SR3-Silonex-datasheet-93144.pdf
You are correct as far as i can see. You can also test this by hooking the led portion up to power + current limiting resistor and measuring the change in the resistance on the LDR portion when power is applied/removed.
Eb7+9
that's right, short pins are the LED - on those pins you'll notice there's a dot next to one of them ...
the dot corresponds to the anode (aNode = Negative) - which is on the bottom RHS in your drawing
TELEFUNKON
Quote from: Eb7+9 on February 24, 2010, 03:39:07 PM
another flower withers  :icon_rolleyes:
TheNixon
Thanks, I just have to make sure I am not using it wrong. I made a circuit using Silonex NSL32 but obviously mistake is somwhere else.
Best regards,
Aljosa
GP
Actually JC, the datasheet clearly states the dot as the CATHODE (i did post a link) but yes it does connect to the negative.
cheers.
Eb7+9
#6
LMAO ... withered indeed
thanks for correcting me, that could save someone's life
:P
