Author Topic: Some messing with Neovibe layouts  (Read 15129 times)
« on: March 08, 2010, 01:11:01 PM »
I've been messing with mods of the Neovibe, and have some new descendents of the line that started back in the mid 90s.
The top entry at http://www.geofex.com is an overview. The middle one is only slightly different from what you can get today at GGG. The biggest difference is using film 1uF caps instead of electros, now that we can get 1uFs that will fit. The same board can be used for electros by bending the leads.
The bottom board is the biggest pads, spaces and traces that I could force myself to do.  :icon_biggrin:  Basically, it's set up for etching and soldering using stone axes for tools. It's hard to get any wider pads and traces in there. Going to jumper wires would help maybe. Haven't messed with that much.
The top board is a drop in fit for the screw bosses in a crybaby shell. As you can see, this is NOT a trivial PCB project. The resistors all stand on end, and the traces are 0.012"/ 0.3mm, and the caps are electros for smallest size. This would be a journeyman  level build, not a first time build, so.
They haven't been checked for errors so those specific layouts may not work - that's a hint that you might be very frustrated if you tried to use those layouts to etch from...  :icon_lol:
MikeH
Re: Some messing with Neovibe layouts
« Reply #1 on: March 08, 2010, 01:42:21 PM »
Oh, that is very cool
bean
« Reply #2 on: March 08, 2010, 01:57:30 PM »
Looks great. My curiosity is definitely piqued by the wah-edition. Some of those traces are a little scary thin for mindless PnP transfers, but with patience I think they won't pose much of a problem. Looking forward to seeing more progress!
« Reply #3 on: March 08, 2010, 03:23:30 PM »
I'd really like to get some beginners' opinions on the bigger one. Is that something that's even interesting? It will still fit inside a 1590DD box, which is a good size for the number of controls. or is 5.0" x 3.8" (127 x 94 mm) just too big?
For the tiny one, it probably needs either photo etching or professional making in a PCB house. It might be that J.D. over at GGG could be talked into doing a panel of them if he was suitably incented...  :icon_lol:
MikeH
« Reply #4 on: March 08, 2010, 03:30:20 PM »
RG, is there a pcb transfer o fthe smallest one that I could print out and look at?
« Reply #5 on: March 08, 2010, 03:59:34 PM »
I'm detecting that there's not a lot of interest in the big, fat, easy to make one, yes?   :icon_lol:
Barcode80
« Reply #6 on: March 08, 2010, 05:20:51 PM »
I actually prefer the larger one, it's just that a direct fit to the crybaby shell is so much more tempting :)
bean
« Reply #7 on: March 08, 2010, 05:27:41 PM »
I'd be willing to test out a couple transfers if you want feedback. I can do traditional iron method and also using my new laminator (which actually works pretty well).
ACS
  • Great Contributor!
  • Total likes: 1
  • They call me Mr. Pig... That or Aidan.
« Reply #8 on: March 08, 2010, 05:40:57 PM »
Sorry for getting OT - laminator: first time I've heard of this for transfer, sounds fascinating... Any links?
RG, personally, I think that a) I'd struggle to get a good clean transfer with the really small one, but (like others) am massively intrigued with getting it into a crybaby shell, and b) the big one is probably too big for my likings - I've got around 15 various builds under my belt, so not massively experienced, but even with my mediocre soldering skills, I feel that it's overkill...
The caveat would be if the big one had direct mounting for footswitch and pots (with subsequently slightly tighter layout), then the size would be perfect  :icon_cool:
Cheers
Aidan
MikeH
« Reply #9 on: March 08, 2010, 06:51:28 PM »
I can't get a feel for whether or not I could do a successful transfer on the small layout without being able to print and examine the traces.
head_spaz
« Reply #10 on: March 08, 2010, 11:44:18 PM »
I really like the second one the best... because I prefer using film caps. And it looks DIY doable.
The small is very nice, but I can't picture wasting a wah enclosure to control it. Would the prefered use be for speed or depth control? If I needed remote control... I'd prefer a rackmounted version with an external multi-treadle pedal.... one rocker for speed... one for depth... and one for regen.
The big PCB is ok. Could probably solder it together using an oxy/acetylene torch.
But put that sucker in a DD box and you'd have to use an external transformer. Not my style.
Deception does not exist in real life, it is only a figment of perception.
« Reply #11 on: March 09, 2010, 09:10:20 AM »
I did the revised layouts based on the comments in another thread that the stock version of the Neovibe was too hard to build and solder. So I thought -OK, let's just make it *big* and let the parts fall where they may.
I find it somewhat curious that the layout that gets the most comments is the smallest, hardest to build one.
MikeH
« Reply #12 on: March 09, 2010, 02:28:41 PM »
You know we love a challenge.  What fun would this stuff be if it was easy?  ;)
kymar
« Reply #13 on: March 10, 2010, 06:39:34 AM »
Nice work!
But, i think, practical application only one will find - the small one.
About power supply - is it so necessary to leave this big caps and bridge? it`s simple to use 24v power adapter.
And what about new mods? Such as using op amps in sound (signal) path (as in voodoolab micrоvibe) or using optocouplers instead of LDRs and lamp.
It must be more interesting.
solderman
« Reply #14 on: March 10, 2010, 11:48:35 AM »
The small one will be no problem to etch and build if you use the fotoresist UV developer method. I have successfolly made 0,2 mm traces with this method. Below is my layout for the ROG Tri Vibe Traces are 0,3 pads are 1,5/0,9mm and spacing to pour is 0,4 mm
www.soldersound.com
« Reply #15 on: March 10, 2010, 12:19:12 PM »
You're right - it's not a problem for photo methods. It is a little bit of a problem for home builders, because it requires a top-side ground plane to make it work as is, but maybe I can eliminate that with some work.
But I was interested in the other end of the spectrum - how valuable to the community getting a bigger, fatter version is. Based on some comments on the existing GGG-supplied Neovibe layout about it being too hard to solder, I thought I'd sample the user preferences, and offer two choices. One is a bigger, fatter, easier to make and solder one, another a smaller, tighter, more bleeding-edge layout.
What I've found is that no one seems to want a fatter, easier to build layout unless it also automates pot wiring and so on and is specific to an enclosure, kind of an easy-kit for an enclosure. So I'm going to go out on a limb and say that there's not much interest in a big, open, simple layout of the Neovibe. I'm guessing that there's more interest, given the general rate of infection with BUMS, in fancy mods and updates of several kinds.
Izzat correct?
MikeH
« Reply #16 on: March 10, 2010, 12:40:36 PM »
Izzat correct?
I'm actually not as much interested in the small one because of the size, what really gets me stoked is that it's set up to go into a wah enclosure.
Barcode80
« Reply #17 on: March 11, 2010, 02:10:43 PM »
Izzat correct?
+1, i ALWAYA prefer larger traces, even though I've got hundreds of builds under my belt, because it just makes things easier. but bolt on fit is way cool.
JBK1
« Reply #18 on: March 13, 2010, 02:37:32 PM »
R.G.  I believe I know which thread you are referring to, I am waiting on a ForumVibe board from him. (Its been three weeks). I didn't know about the Neovibe until after I  placed my order. I plan to build the NeoVibe also , maybe I'll build them at the same time. I would be glad to share my thoughts with you about the ease or difficulty of the builds. I am currently finishing my first build, but don't consider myself a beginner. I am a Biomedical Equipment Tech by trade, I have experience in electronic repairs, but not much experience in building pedals.
I built my own board for my first build and getting ready to build another board, both are small, not very complicated layouts. I was considering buying the Neo board from GGG, but I may give etching the Neo my self, (If I can get a copy of the layout).
« Reply #19 on: March 13, 2010, 02:57:06 PM »
I've been messing with the Crybaby bolt in some. I got the single-pot mod on it, managed to use a few jumpers instead of a ground plane so it's one sided, and I'm working on making the board fit the plug-on connector in the middle generation of wah pedals. Don't know if that'll pan out, but it's neat if it does.
Hmmm... how about Cry-Vibe-y?  :icon_eek:
