Author Topic: MXR Distortion III vero?  (Read 19074 times)
philbinator1
« on: March 24, 2010, 09:43:38 AM »
Does anyone have this vero that they could post/pm me?  I looked in the gallery and googled, came up zip.
cheers
phil
"Hows are we's?  We's in the f*cking middle of a dinners meal!  Dats hows we am!" - Skwisgaar Skwigelf
philbinator1
Re: MXR Distortion III vero?
« Reply #1 on: March 24, 2010, 05:06:14 PM »
bump for extra vero-y goodness?
« Reply #2 on: March 24, 2010, 05:07:36 PM »
If no one has one, point me in the direction of the schematic and I'll see what I can do.
philbinator1
« Reply #3 on: March 24, 2010, 05:13:39 PM »
http://analogguru.an.ohost.de/001/schematics/Mxr_Distortion-III.gif
and the thread that goes with it:
http://www.free stomp boxes.org/viewtopic.php?p=255&mforum=free stomp boxes
EDIT:  I had to put spaces in there, it wouldn't let me post the name of that website!?!  crazy
« Last Edit: March 24, 2010, 05:15:53 PM by philbinator1 »
MikeH
« Reply #4 on: March 24, 2010, 09:32:16 PM »
I don't know how helpful this will be to you, but it's AWFULLY similar to the Zakk Wylde OD, except it has clipping diodes to ground between stages instead of in the feedback loop.  And I know there's a ZW OD vero layout floating around somewhere.
Brymus
  • Poster2
  • Total likes: 1
  • Bryan G. - Somewhere in the Mohave Desert USA
« Reply #5 on: March 25, 2010, 12:40:49 AM »
Can you post/PM me the Zak Wylde version schematic the link at the other place is broken?
Thanks Bryan
« Reply #7 on: March 26, 2010, 04:45:45 PM »
Here you go
The component numbering follows Analogguru's schematic. I've left off Q4 and associated components, looks like that just mutes the input using the original switching, using true bypass switching it's not needed.
Shift a couple of components and you can build the ZakK Wylde with it as well.
philbinator1
« Reply #8 on: March 26, 2010, 07:41:39 PM »
Here you go
thanks so much for doing that man!  i'll start tomorrow, really looking foward to it  :)
EDIT: do you know the value of c8?  its not on the schem.
« Last Edit: March 26, 2010, 07:47:25 PM by philbinator1 »
« Reply #9 on: March 27, 2010, 07:14:17 AM »
No problem, after I posted it I realised the vero had a couple of errors, I've corrected them now and uploaded a new version. The image should refresh to the new version, if not go here http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/mxrdist3board.jpg.html?g2_imageViewsIndex=1
I don't know what value C8 should be, on the Zakk Wylde schematic which has the same arrangement its 4u7 it probably doesn't matter much I'd guess 10uF or even bigger would work fine. R6 doesn't have a value either, it's 33k on the Zakk Wylde so I'd just go with that, it just sets the minimum amount of gain, which you're probably not going to use so any similar value would be fine.
Let me know how you get on with it.
« Last Edit: March 27, 2010, 07:16:35 AM by slacker »
philbinator1
« Reply #10 on: March 30, 2010, 08:41:21 AM »
just bumping this...
i'm itching to build this but don't don't have any 220pF caps.  i'm gonna buy some, but can i use regular old ceramics for this value?
and do the kind of caps you use matter overly?
cheers
phil
MikeH
« Reply #11 on: March 30, 2010, 09:39:34 AM »
cheers
phil
I don't see a 220pf cap on the schem... I see a 220uF; is that what you mean? Where is the cap you're talking about?
philbinator1
« Reply #12 on: March 30, 2010, 10:21:50 AM »
sorry my mistake, it's 120pf, it's C12.  tell you what don't worry about replying, i have other questions about the schem i'll ask tomorrow when i don't have brainfuzz...gotta go to bed now zzzzz   :)
« Reply #13 on: March 30, 2010, 12:31:24 PM »
It will work fine without C12 so you could just build it and add that when you've got a suitable cap. Any similar value will work fine, doesn't matter what sort of cap it is.
CynicalMan
« Reply #14 on: March 30, 2010, 04:14:08 PM »
I'd just like to point out that I've modded one of these and it sounds a lot better without C4.
philbinator1
« Reply #15 on: March 31, 2010, 07:47:09 AM »
Ok here are some q's i had about the D3 schem:
* Some of the resistor values have 'E' after them - what does this mean?  is it another letter for Ohms, like 'R'?
* Why is R15 and R16 missing off the schem?
* There are 2 symbols that could be ground; one looks like half a cap symbol, the other is a line with a dot through it.  which is ground, and which is the other?
* Do we have concrete values for R6, C8 and Q4?
* Are the caps with one side black/one white polarised?
* The three pots (VR 1,2 and 3) have either 'D' or 'W' after them.  What kinds of pots are these?  Lin, log, or reverse-log?  Or other?
* Can the IC (MC33178P) be subbed out for something else?  741 etc?
* Is 'S1a' and 'S1b' part of the jack(s)?
* Is it possible to use a ceramic cap for C12 (120pF)?
* What is that symbol in the top left-hand corner of the schem?
I know that's a hell of a lot of questions!   :o  Very demanding of me but i like to be prepared/thorough...it will help others too.  If it's ok with Slacker I might take his vero and attach the info/component values (which got from Slacker) so you guys can download it as a single gif or jpg or whatever.  If someone could answer anything off the list i would be very grateful, thank you.    :)
Schematic:
http://i809.photobucket.com/albums/zz13/philbinator1/MXRDistortionIIIschematic.gif
Vero:
http://i809.photobucket.com/albums/zz13/philbinator1/MXRDistortionIIIvero.jpg
« Reply #16 on: March 31, 2010, 01:14:16 PM »
I can't answer all the questions but here goes.
Yeah, it's another way of saying Ohms.
Who knows, the numbering is taken from the PCB, maybe they just didn't exist or were part of the LED switching, which isn't shown on the schematic. There doesn't appear to be any missing components on the schematic if that's what you mean.
The thick black line, like the one on the bottom of the output pot is ground. The other symbol is 4.5 volts made by R8 and R9.
Don't know about R6 and C8, the values from the Zakk Wylde will work fine, Q4 isn't on the vero layout so I wouldn't worry about it :)
Yeah, the white side is positive.
Not sure about 'D' log will work fine for the output and linear for the distortion. W is a special tapered pot, that's like half log and half reverse log. Smallbear sells them, or you can use linear but the "feel" of the tone control will be a bit weird.
You can use pretty much any dual opamp like a TL072 or a 4558.
That's the stomp switch for bypassing the effect.
Any sort of cap will be fine.
If you mean the thing above the battery I think it's the DC jack.
Schematic:
Vero:
Not trying to have a go at you, but it's not really cool to host the schematic on photobucket, it even asks you not to on it :)
I don't care about my layout, you can do what you like with that.
« Last Edit: March 31, 2010, 01:16:25 PM by slacker »
MikeH
« Reply #17 on: March 31, 2010, 01:19:46 PM »
FWIW I've never been bothered by using a linear pot in place of a "W" taper.  It's the same as the tone control pot on a tubescreamer, and many similar clones.  Linear sounds just fine to me.
« Reply #18 on: March 31, 2010, 01:22:14 PM »
Cool, to be honest I've never tried it, if you can believe it I've never built a TS clone :)
MikeH
« Reply #19 on: March 31, 2010, 01:26:11 PM »
No I can't believe it.  I wish you wouldn't lie to me like that.  >:(
