Author Topic: pix of Custom built guitar amps/cabs  (Read 443399 times)
danielzink
Re: pix of Custom built guitar amps/cabs
« Reply #140 on: January 21, 2011, 07:42:30 PM »
My first Firefly.....
Celery_Strat
« Reply #141 on: February 05, 2011, 03:15:36 PM »
Very nice looking FireFly there.
a soBer Newt
« Reply #142 on: March 14, 2011, 06:53:34 PM »
This is an old amp that i took out of a reel to reel that was not longer working using 2 of the 3 12ax7 the output tube is a 6AQ5A. Still need to replace the filter cap but it works and sounds great maxed.
HOTTUBES
« Reply #143 on: March 27, 2011, 02:37:02 PM »
To all who have posted there custom work on this thread !!!
A tip of the Hat to you all !!   Your work is just Incredible !     :o
MikeH
« Reply #144 on: April 08, 2011, 10:54:28 PM »
Lots o' fireflies in here... here's mine:
tasos
« Reply #145 on: April 09, 2011, 04:31:52 AM »
great!red tolex is so sexy!aren't you going to put a handle on it? :icon_razz:
p_wats
« Reply #146 on: April 09, 2011, 02:21:15 PM »
Might be small, and might be solid state, but it's still a guitar amp...and 20 watts too!
It's Taylor's Tiny Giant Amp from musicpcb.com. Great sounding little guy:
MikeH
« Reply #147 on: April 10, 2011, 02:15:02 PM »
I was, but then I thought "I'll never take it out of my house, and it probably weighs about 5 lbs... anywhere I need to move it to, I'll just pick it up and carry it."  And thats what I do.
And that's actually not tolex; it's some vinyl 'marine' fabric I got at the fabric store.  The look is similar, but it's softer to the touch.
tasos
« Reply #148 on: April 10, 2011, 02:41:12 PM »
i am so turned on! ;D
Govmnt_Lacky
« Reply #149 on: April 10, 2011, 04:15:01 PM »
Can someone tell me what is the name of this particular type of PCB/board?
Not the name of the circuit but, the actual name of the board style/material. Its not vero, or regular PCB. It has the posts on the sides of the board to solder point-to-point.
Thanks  ;D
for an amount of ‘up to and including my life.’
G. Hoffman
« Reply #150 on: April 10, 2011, 04:45:26 PM »
Thanks  ;D
It's a turret board.
Gabriel
Govmnt_Lacky
« Reply #151 on: April 10, 2011, 05:35:24 PM »
Thanks Gabriel. I dont use them personally but, I recently came across a few brand new TURRET BOARDS and had no idea what they were  :icon_redface:
p_wats
« Reply #152 on: April 10, 2011, 09:55:20 PM »
It's a homemade turret board using plexi-glass (I think) and rivets. Does the job really well!
I'm trying terminal strips for the next one though...
Thomeeque
« Reply #153 on: May 13, 2011, 08:42:32 AM »
 Hi, my Vox V212BN, freshly comboized :)
 Find more pics here..
 Cheers, T.
Do you have a technical question? Please don't send private messages, use the FORUM!
John Lyons
« Reply #154 on: May 15, 2011, 02:36:31 AM »
Can we get some better pics Thomeeque?  :D (a joke)
Nice work!! Can you tell us more about the amplifier in there?
What is it actually?
Great job.
Basic Audio Pedals
www.basicaudio.net/
Thomeeque
« Reply #155 on: May 16, 2011, 06:15:16 AM »
Great job.
 Thanks, John!!
 Conceptually it is one channel solid state 35W/16Ω (50W/8Ω) guitar amp with guitar level input, Bright boost switch, 3-band EQ, Gain and (Master) Volume controls and very simple "tube-amp modelling" (just simple soft-clipping applied at the pre-amp out). There is only "Standby" (Mute) switch, no power switch (it significantly simplifies lethal wiring and first tests show no drawbacks so far, quiescent load from mains is cca 6W), dual-color LED indicates actual state (RED = standby, GREEN = on).
 Primary goal was to get transparent PA for the signal already completely cooked by my pedalboard, but it is able to be overdriven to blues/rock kind of distortion in simple guitar->cable->amp configuration.
 As an pre-amp I have used just very slightly modified Rod Elliott's pre-amp from his 100W Guitar Amplifier Mk II project (I have removed R2, LO in, VR4, R10 and whole output buffer and I have replaced R12 by A100k "GAIN" pot.. and bridged Bright switch by 100k resistor to make it's switching popless.. and used 7815/7915 pair for ±15VDC regulation).
 As an power amp I have used LM3886 based kit.
 There are few threads related:
 LM3886: Vs = ±35VDC, Load = 16Ω, Pout = 35W - right?
 Solid-state guitar combo amp: using speaker-forced airflow for cooling heatsink
 optimal toroidal transformer mounting
 Old CPU-cooler as an LM3886 heat-sink
 I'm still testing it (my biggest concerns are LM3886 cooling and danger of parasite sound effects caused by stuff added inside), so far I've used it only at one rehearsal and it seemed OK (but it was a cool day and I could not go to the highest volume levels), today is next rehearsal and at Wednesday we have a gig (and that's where it all will go wrong :icon_mrgreen:  .. but I'll have some backup there).
 Cheers, T.
« Last Edit: May 16, 2011, 08:46:49 AM by Thomeeque »
John Lyons
« Reply #156 on: May 16, 2011, 03:27:01 PM »
Very nice, thanks for the details.  :icon_wink:
Basic Audio Pedals
www.basicaudio.net/
Unkn0wn Art1st
« Reply #157 on: May 16, 2011, 06:04:21 PM »
my first amp :3
Inspired by old soviet solid state transformer design. Totally recycled btw
some guts:
now working on power supply, more pics soon.
Taylor
  • Total likes: 79
  • The clean energy source of the future.
« Reply #158 on: May 16, 2011, 06:24:59 PM »
Wow, that's really cool.
terminalgs
« Reply #159 on: May 19, 2011, 03:32:29 PM »
5E3 circuit in an old webcor cabinet.   10" weber alnico.
point to point with tag strips, two chassis's, (upper
and lower),   hand made.
