Author Topic: pix of Custom built guitar amps/cabs  (Read 443975 times)
Cozybuilder
Re: pix of Custom built guitar amps/cabs
« Reply #540 on: June 19, 2015, 11:54:46 AM »
Thomas- Beautiful build, so naturally this sent me down a rabbit hole to search out appropriate output transformers. An entertaining morning.
« Reply #541 on: June 20, 2015, 11:48:11 AM »
...naturally this sent me down a rabbit hole to search out appropriate output transformers.
Let me know if you find anything :) Also seriously considering building one of these. 8)
Cozybuilder
« Reply #542 on: June 20, 2015, 12:49:17 PM »
Nate- I ordered this:
http://www.ampmaker.com/store/4W-push-pull-output-transformer.html?printable=Y
2 including shipping was under $40.00
« Reply #543 on: June 20, 2015, 06:23:11 PM »
tca
« Reply #544 on: July 02, 2015, 04:59:53 AM »
One more!
Elijah-Baley
« Reply #545 on: July 02, 2015, 05:32:09 AM »
tca, interesting this little monster! ;)
What is the project?
tca
« Reply #546 on: July 02, 2015, 05:39:35 AM »
^ Pretty basic, a 1W class A mosfet power amp, with bias control and lineout with vol.
« Reply #547 on: July 02, 2015, 05:47:33 AM »
nice, looks very etchable too.. 8)
tca
« Reply #548 on: July 02, 2015, 05:57:33 AM »
... and hot, it has a resistor load which dissipates about 10W in heat + 3W of heat of the mosfet. That's why it looks like a monster.
« Reply #549 on: July 02, 2015, 06:02:01 AM »
you built a radiator..
or you can warm soup on it too... ;D
Elijah-Baley
« Reply #550 on: July 02, 2015, 06:03:02 AM »
I'd like to read a report of this project.
Can you tell us how it is comparing to the Punch Amp? It sounds clean? It is noisy? It supports 8 ohm speaker? Eq is ok?
Don't call me "inquisitive". :P
Thank you a lot! ;)
tca
« Reply #551 on: July 02, 2015, 06:19:47 AM »
Sounds much better, overdrives nicely with a booster in front of it. Sounds clean with good compression, high output impedance, can drive 8/16Ohms cabs.
Full details here: http://www.diystompboxes.com/smfforum/index.php?topic=111487.msg1025878#msg1025878
Cheers.
Brisance
« Reply #552 on: July 02, 2015, 07:08:05 AM »
Not directly by me but I am affiliated with a company that makes these and helped with building this particular one
Buildtestrepeat
« Reply #553 on: July 03, 2015, 07:39:00 AM »
A bit rough and ready compared to others on this thread.  However, it works and I'm happy with it.  This is my 'Lamington' 15w build housed in modified Ikea.
« Last Edit: July 03, 2015, 07:49:05 AM by Buildtestrepeat »
tca
« Reply #554 on: July 03, 2015, 09:35:36 AM »
Buildtestrepeat: What are  that corner protections? Similar to the ones used by midwayfair in his amplifier.
Modified Ikea box?
Looks great!
diydave
« Reply #555 on: July 03, 2015, 10:34:16 AM »
Nice build.
Love the way the mesh is used.
Buildtestrepeat
« Reply #556 on: July 03, 2015, 07:56:00 PM »
Modified Ikea box?
Looks great!
The corners are very similar if not the same as those in midwayfair's post.  I got them at a hardware store.  The box is from a small storage unit called 'Trofast'.  I just used the top and bottom of the unit and cut down the sides to the right height.  A small amount of routing and a few drill holes and it was done.  I can unscrew the box and make it flat pack again  :icon_biggrin:.  The mesh is cut from the bottom of a storage tray and painted gold, then just screwed on inside the front panels.
Cheers for the likes.
tubelectron
« Reply #557 on: July 17, 2015, 06:00:29 PM »
Hello DIYers All,
I came to compliment that thread of exhaustive nice amp and cabs releases all around...
Here is my last creation, designed and built from scratch, and just finished these days, a 50's-60's styled guitar amplifier :  The COMET .
If you don't like that vintage style, it would be better for you to skip... But if (like me) you like it, then enjoy :D !
Note that it is a personal, non-commercial production : I have nothing to sell and sell nothing... That must be said to avoid any misundertanding about the aims of my releases.
Let's go :
At the start, plywood and aluminum :
The UTAH AlNiCo restored/reconed 10" speaker form 1957 :
The faceplate and logo, vectorial drawn and laser etched :
The Tolex covering color choice (Ivory White / Surf Green) and grillcloth pattern (Fender BlackFace RI white-silver-black) :
Assembling the cab (nailed-screwed-Vinyl glued, angle-braced) and presenting chassis :
Presenting loudspeaker ans chassis :
Covering and Grillcloth-ing :
Chassis preparation, drilling and surface "bouchonnage" :
Chassis assembly and wiring :
The finished amplifier :
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
« Reply #558 on: July 17, 2015, 06:07:23 PM »
Stunning work Bruno, absolutely gorgeous! Thanks for sharing.
How many hours do you think you need to finish such a project?
Thanks,
dave
Cozybuilder
« Reply #559 on: July 17, 2015, 06:12:11 PM »
The cool factor meter just broke  :icon_cool:
Thanks for sharing
