Author Topic: pix of Custom built guitar amps/cabs  (Read 443094 times)
Joncaster
Re: pix of Custom built guitar amps/cabs
« Reply #780 on: July 10, 2018, 02:43:59 AM »
Just finished this one. Rick Holt's (aka frequencycentral) Superfly, which is an submini version of Doug Hammond's Firefly, built in a 1590A.
Woah, that's next level.
Music is Eternity: stretched like the sky over the landscape of our lives.
"It's better to be looking at it, than looking for it."
My Band:
http://www.coldwatermorning.bandcamp.com
Perrow
« Reply #781 on: July 10, 2018, 02:52:26 AM »
Nah, just a copy cat ;)
https://www.diystompboxes.com/smfforum/index.php?topic=94741.0
Nice to see someone else tackle (and succeeding with) this build  :D
Marcos - Munky
« Reply #782 on: July 10, 2018, 05:27:01 PM »
Mine isn't next level, just a poorly done copy of Perrow's :icon_lol:
It's indeed a challenging build, not so much space to use and everything must be well planned before the building process. Perrow's work is fully detailed to avoid all that planning, and I was going to use all that info. But since I used russians tube (with different pinouts) I had to do everything from the start, and had to make a few decisions (including no tonestack nor bias switch, since I used a low gain preamp tube) which resulted in a amp different from the initial plannings. The most important things are: 1) it works; 2) I really enjoyed the sound :icon_razz:.
As stated at Perrow's Superfly page: Measure 42 times drill once.
dan.schumaker
« Reply #783 on: July 17, 2018, 02:23:29 PM »
Here are a few of mine I've done:
AC-15 build with Mahogany cabinet, dovetailed joints
18 Watt with Cherry Cabinet
Overload Special
Brownface Princeton
Blackface Princeton
stallik
« Reply #784 on: July 17, 2018, 06:05:44 PM »
That’s some seriously good work there!
Joncaster
« Reply #785 on: July 18, 2018, 03:49:44 AM »
That is beautiful
My Band:
Govmnt_Lacky
« Reply #786 on: July 20, 2018, 01:44:13 PM »
Overload Special
Brownface Princeton
Blackface Princeton
Hey Dan. How did you do the faceplates on these? Trying to get something like this done for the amp I built. Thanks!
for an amount of ‘up to and including my life.’
thermionix
  • Guest
« Reply #787 on: July 23, 2018, 05:08:00 AM »
There used to be a place called amplates.com that would make custom faceplates, logos, and even printed grill cloth.  But they quit taking orders according to their site.  No idea if any of the print shops like Fast Signs can do anything similar.  Worst case scenario you can print on paper and put clear plexiglass over it.  It looks okay but the plexi can crack from tightened pot/jack/switch nuts.  Trophy shops can help with some things.
dan.schumaker
« Reply #788 on: July 23, 2018, 03:18:39 PM »
I do them the same way I do pedals.  These are just clear sticker paper on some aluminum sheet (like this https://www.menards.com/main/tools-hardware/sheet-metal-rods/hillman-reg-aluminum-sheet-metal/11237/p-1444432417564.htm), then clearcoated over.  Super easy to do!
« Reply #789 on: July 26, 2018, 02:46:03 PM »
I've been working on this one for a while and it's finally finished enough :P It's a Bogen Challenger 100 that I converted into a 100W bass amp for a friend. He gigs regularly so he wanted it to be a rackmount for easy traveling. The chassis is 1U but the transformers and everything make it 3U tall, so I made a 2U crylic plate with CNC engraved labels and threw an LED strip behind it.
wavley
« Reply #790 on: July 30, 2018, 12:01:02 PM »
I finished up a couple of builds this week.
« Last Edit: July 30, 2018, 12:06:39 PM by wavley »
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
« Reply #791 on: July 30, 2018, 12:35:18 PM »
I finished up a couple of INSANELY SEXY builds this week.
Fixed that for you. Really excellent builds, and your guts are neater than mine will ever be 8)
What circuit is this, if you don't mind my asking? EL84's through hemp speakers are my favorite sound in the world ;D
wavley
« Reply #792 on: July 30, 2018, 12:49:57 PM »
The gutted vaporizer was pretty free form, I threw in a couple turret strips and a ground buss and built from pile of schematics.  Basically it's the power section and PI from the EL84 Traynor YBA-2AB Bass Mate, but cathode biased, and the preamp/tone stack from the Traynor YSR-1 Custom Reverb.  A few tweaks here and there, like using a tweed choke power supply, but with a bridge rectifier.  I built it for Alan from the Findells so he would stop needing to use my modded Vibrolux in the studio and a Blues Deluxe live, it's dark and growly just like it's owner and just loud enough to compete with Paul the drummer.
« Last Edit: July 30, 2018, 12:52:16 PM by wavley »
Joncaster
« Reply #793 on: July 30, 2018, 02:23:37 PM »
Amazing builds!
My Band:
thomasha
« Reply #794 on: August 12, 2018, 06:16:16 AM »
Finished another submini amp>
this time running on batteries!
« Reply #795 on: August 12, 2018, 06:46:34 AM »
Lovely, indeed! <3
How many watts? Which tubes did you use?
thomasha
« Reply #796 on: August 12, 2018, 08:27:21 AM »
well...0.3W  and the tubes are the 1J24B and the 1J29B russian subminiature tubes.
Only 35mA filament current in the series string.
thomasha
« Reply #797 on: August 15, 2018, 04:08:42 PM »
just made a video to show how it sounds.
In the end I test the high gain/volume setting to show some feedback
sgcoguy
« Reply #798 on: August 16, 2018, 04:40:38 PM »
Another Ruby amp....
I've been a lurker on the board for a while and I've built a few DIY pedals, but this is my first attempt at an amp.  It's a ROG Ruby built into a "craft" box.  I used two 3" speakers I had laying around.  I still need to stain the box, but I'm very happy with it.  I was surprised by how easy it was to build and how good it sounds (even with 3" speakers)!
Marcos - Munky
« Reply #799 on: August 16, 2018, 05:06:21 PM »
Welcome, sgcoguy. Nice amp, just put something to protect the speakers.
