Author Topic: pix of Custom built guitar amps/cabs  (Read 416164 times)
mth5044
Re: pix of Custom built guitar amps/cabs
« Reply #840 on: March 06, 2019, 11:48:59 PM »
Oh my gosh. I feel things about this I haven’t felt since...
« Reply #841 on: March 07, 2019, 06:14:19 PM »
Hi!
just made a paint job on the original schematic...here you have it:
For a bigger image just copy the link and remove the last l before the dot
If you want to use a 12AX7 in the tremolo you can use the original tremolo section, with only 3 CR Stages.
As long as you have the filament centre tap available, I would connect it to some higher voltage like the cathode of the output tube.  This is often done to ensure any electron emission from the filament starts at a higher voltage so the grid will be much more negative and will shut it off.
« Reply #842 on: May 03, 2019, 11:49:22 AM »
If I use DC for heaters, is it better to connect heater's ground to output tube's cathode or not?
« Reply #843 on: May 03, 2019, 05:41:41 PM »
[/quote
I would still connect the heaters to a higher voltage like the output tube cathodes because rectifying and filtering the AC heater supply would introduce higher harmonics of the power line frequency even though the fundamental would be gone.
« Reply #844 on: May 04, 2019, 10:02:57 AM »
If I got this right - for example, I have 9V DC available for heaters (as in normal pedal) and they need 6.3V. Which version is better (if any) - with heater ground slightly elevated to 2.7V with dropping resistors between heaters and ground, or heater ground at the same level as circuit ground, with dropping resistors between +9V and heaters?
Toynbee
« Reply #845 on: June 23, 2019, 10:34:31 AM »
Marcos - Munky
« Reply #846 on: June 26, 2019, 08:42:31 PM »
Just finished this one. AX84 P1 with "alternative" tubes. I've used a 6N2P for the preamp tube, and a 6EM5 for the output tube (not pin to pin equivalent to a EL84). Also, my first experience on winding both power and output transformers.
« Last Edit: June 26, 2019, 08:46:09 PM by Marcos - Munky »
Ben N
  • Total likes: 520
  • Ben N. - really! Now Israel, once Baltimore
« Reply #847 on: June 27, 2019, 04:18:55 AM »
Is that one of those tone-metal cake tins?
Marcos - Munky
« Reply #848 on: June 27, 2019, 06:10:35 PM »
Yeah, it's a tin to bake cake/bread.
Thomeeque
« Reply #849 on: September 20, 2019, 08:26:00 AM »
 Hello,
 I needed minimalistic setup for my home looping and it led to the need of building FX loop feature into my MicroCube (there was simply no other way around :D).
 It was not that easy, as all from preamp to master volume happens inside the CPU, but I managed.
 Short sample
 More pics & schema
 Happy :), T.
Do you have a technical question? Please don't send private messages, use the FORUM!
Ben N
  • Total likes: 520
« Reply #850 on: September 22, 2019, 02:44:31 AM »
Tomas, you never fail to amaze.
Thomeeque
« Reply #851 on: September 23, 2019, 05:17:50 AM »
 Oh, sweet, thank you, Ben! :)
« Reply #852 on: September 23, 2019, 11:26:19 AM »
Are you sure...? ???
Looks great though, nice work 8)
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
« Reply #853 on: September 25, 2019, 03:14:31 AM »
tomaz thats brilliant, i have a micro cube too, and a looper,
its always been a pain that the effects come after, so i can see why you did this....excellent work man.
(i was forced to use mine on clean channel with external effects and looper....)
so this is a nice minimal setup...very cool.  8)
Thomeeque
« Reply #854 on: September 26, 2019, 10:35:24 AM »
Thanks, guys! :)
 Well, depends. I really like preamps and effects built-in inside MC, it's just a perfect set for (my) home playing needs, and to be able to use them in combination with looper IMHO there is no other way. You can use it the way Rob describes, but then you loose most of what MC offers and setup is also more complicated.
tomaz thats brilliant, i have a micro cube too, and a looper, ..
 Then you should do it also! :icon_twisted: I can provide some more info, if needed, feel free to ask.
 Cheers, T.
« Reply #855 on: September 26, 2019, 10:43:08 AM »
hi T.
yes please, i'll have a go at it...
ive done a few mods to it already, added an on/off switch on top...as the one on the back was annoying.. :icon_rolleyes:
added a speaker on/off regardless of phones in...for recording out... 8)
and added fancy colour changing neo pixel leds around the face of it too.... ;D
so may as well go the full monty on it... :icon_mrgreen:
Thomeeque
« Reply #856 on: September 26, 2019, 10:50:38 AM »
That's the spirit! :icon_lol:
Thomeeque
« Reply #857 on: October 04, 2019, 03:30:39 AM »
hi T.
 I started new topic: /smfforum/index.php?topic=123179.0 ✌️
Marcos - Munky
« Reply #858 on: December 02, 2019, 08:29:43 PM »
This is a EF184 tube preamp + a TDA8932 class D amp board.
I used a laptop power supply (19V) to power the whole thing. The TDA board is powered by the laptop power supply. Then I used a dc-dc step down converter to lower it to 6V to power both the heater and a 555 smps for the high voltage (which I forgot if it was 150V or 250V, probably 150).
« Reply #859 on: December 03, 2019, 03:49:51 AM »
Great, Marcos! I'm just in the process of deciding how to power my new mic pre, and I thought I could do SMPS, too! I've got some Chinese DC-DC converters for cheap, so I will experiment with them. My idea is to go 12V (for heaters) and then boost that to 220-250V for B+. What's your experience with this - is it noisy or not?
