Author Topic: clean sound no distortion  (Read 8098 times)
clamup1
« on: April 10, 2010, 02:46:01 PM »
i bread boarded this and im having trouble figuring out where to put the #1 wire from the pot . also prob a really dumb ? but the black transistor, does the semi circle go toward you are away from you?
thanks
aron
Re: clean sound no distortion
« Reply #1 on: April 10, 2010, 03:13:10 PM »
Here is how the pot is wired:
The transistor orientation depends on the transistor used. You need to look it up. For example, click on the datasheet link in here:
http://diystompboxes.com/zencart/index.php?main_page=product_info&cPath=12&products_id=31
Aron
clamup1
« Reply #2 on: April 10, 2010, 04:37:08 PM »
i think i got that figured out but i think my capacitors are bad. i have power going into one and none coming out the other side. im on hold for a couple of days
clamup1
« Reply #3 on: April 10, 2010, 04:51:20 PM »
im using 47uf 50v, and a 10uf, 25v. those are too high. i need lower v right?
aron
« Reply #4 on: April 10, 2010, 06:00:49 PM »
no, the voltages are not too high. The larger the voltage the bigger the size of the cap usually, but as long as it can handle 9V, it's fine.
clamup1
« Reply #5 on: April 11, 2010, 01:17:16 PM »
thanks for your help. i think i figured it out. ive got the 5k pot line and the output line tied together. i havnt gotten a chance to work on it so ill let you know.
aron
« Reply #6 on: April 11, 2010, 03:32:19 PM »
Good luck. Hopefully it works now.
clamup1
« Reply #7 on: April 12, 2010, 05:21:36 PM »
i have torn this thing apart and put it together 6-7 times and i dont know whats wrong
/img]
any help would be helpful
clamup1
« Reply #8 on: April 12, 2010, 05:22:13 PM »
sorry
clamup1
« Reply #9 on: April 12, 2010, 05:25:13 PM »
i have no power to the .1uf at the begining and the juice gets to the 47uf and stops. i am getting no signal at all now
clamup1
« Reply #10 on: April 13, 2010, 07:50:14 AM »
askwho69
« Reply #11 on: June 25, 2010, 10:10:37 AM »
wat does 47uf do in the 5k pot?
"To live is to die"
blackcorvo
  • Great Contributor!
  • Total likes: 6
  • Lucas, Guitarrist wannabe, Loves electronics/music
    • My Youtube Channel
« Reply #12 on: September 24, 2010, 04:19:57 AM »
it increases the gain of the circuit when you roll the 5k pot's knob all way up.
i have built this circuit in protoboard, using a 10k pot for the gain with a 12k resistor in paralel to it (that is the closest to 10k i got here), and it worked just fine.
