Author Topic: bread board prob  (Read 7682 times)
clamup1
bread board prob
« on: April 13, 2010, 02:23:54 PM »
i believe i have it right but i dosnt get any sound. if anyone can debug this for me it would be appreciated
schematic
im not gettting any sound
aron
Re: bread board prob
« Reply #1 on: April 13, 2010, 03:08:11 PM »
I don't see anything connected to the input cap. The guitar signal has to reach the input cap to have sound.
Aron
clamup1
« Reply #2 on: April 13, 2010, 03:18:01 PM »
if your talking about the wires from the jacks i left them off to make it easier to see. i can put them on and take another pic.
aron
« Reply #3 on: April 13, 2010, 05:22:47 PM »
I don't see it either. From what I can see it looks correct but I get a headache when trying to follow a breadboard. What kind of transistor? Check the orientation of the transistor and caps.
clamup1
« Reply #4 on: April 13, 2010, 09:10:13 PM »
i checked the transistor and the caps theyre facing the way theyre supposed to be facing heres the pic with jacks
the transistor is a 2n3904
« Last Edit: April 13, 2010, 09:15:50 PM by clamup1 »
aron
« Reply #5 on: April 14, 2010, 02:51:38 PM »
I can't figure it out. Anyone else want to try? Measure voltages at the pins of the transistor.
arma61
« Reply #6 on: April 14, 2010, 04:15:36 PM »
providing each arrow points to the right component, aren't you missing the connection +22uF,10k,100k,47k.
also where is your output wire, is the white on top right? then it's connected to ground
Cheers
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
clamup1
« Reply #7 on: April 14, 2010, 07:59:36 PM »
so would i hook the white output wire to the - side of 10uf?
ran 100k from +bus to 22uf, orange jumper, 47uf
so i need E---22uf--------100k-------- + bus
                      I
                      I
                    47uf
 i dont know how to connect the 22uf and the 100k to the circuit
« Last Edit: April 14, 2010, 08:12:53 PM by clamup1 »
arma61
« Reply #8 on: April 15, 2010, 03:52:28 PM »
sorry m8 I'm in a hurry now, but try this : move the white wire and the blue jump at the end of the black lines I've drawn, that shoud fix it.
Ciao
Armando
clamup1
« Reply #9 on: April 15, 2010, 09:51:24 PM »
so im hooking the blue jumper to the 10k resistor and then moving the 47uf cap right?
thanks for your help. i got noise but i have to pick hard and have my guitar and the pedal turned all the way up.
« Last Edit: April 15, 2010, 10:20:07 PM by clamup1 »
arma61
« Reply #10 on: April 16, 2010, 06:58:25 AM »
Sorry for confusing you Chris!
leave the blue jumper there, and add a wire from F15 to c10, that should make the connection +22uF,10k,100k,47k
Ciao
clamup1
« Reply #11 on: April 16, 2010, 10:13:08 AM »
thanks armond. i got it to work. except theres no distortion. i like the added boost and if i turn on the gain and reverb on my amp it sounds cool.
« Last Edit: April 16, 2010, 11:00:12 AM by clamup1 »
arma61
« Reply #12 on: April 16, 2010, 11:47:03 AM »
there's no distortion ? that's great it's not supposed to distort ;D , just to boost your signal.
just one pot, the one called Boost 5K
Ciao
clamup1
« Reply #13 on: April 16, 2010, 09:01:39 PM »
well good then that pedal is a win. thanks for your help
arma61
« Reply #14 on: April 17, 2010, 03:45:04 AM »
u r welcome m8
have fun !
