Author Topic: Building the tap tempo tremolo  (Read 318826 times)
alparent
Re: Building the tap tempo tremolo
« Reply #1000 on: September 10, 2018, 12:34:13 PM »
To bad they are not 16 pin! I could have sanded them down and sold them as SAD1024 on ebay.
« Reply #1001 on: September 11, 2018, 03:09:44 AM »
What I'm I suppose to do with all those PIC 16F684 now!?
I think we need to see a picture of you wearing these, Tom!   ;D
Mcintosh
« Reply #1002 on: September 29, 2018, 04:02:04 PM »
Built this fine pedal today!! Version.3 ic. Subbed volume pot for the Switch mod for different wave forms, cool! Grounding pin 6 helped a lot with the different wave forms. Nice!
« Reply #1003 on: September 30, 2018, 08:55:48 AM »
Welcome! And very glad to hear it worked well for you!
Barcode80
« Reply #1004 on: October 07, 2018, 12:43:55 PM »
***Deleted because I'm a dumb.***
« Last Edit: October 07, 2018, 01:07:39 PM by Barcode80 »
Barcode80
« Reply #1005 on: October 07, 2018, 12:54:18 PM »
« Last Edit: October 07, 2018, 01:07:32 PM by Barcode80 »
telebiker
« Reply #1006 on: November 21, 2020, 08:14:45 PM »
Finally it is done (PCB ordered in 2012).
Many thanks to ElectricDruid and Taylor for the help during the build, I had a lot of questions.
Mods:
- TAPLFO3 with Waveset and Smooth switched
- Center detent pot for the Offset knob (it's easy and I find it very useful)
- 4 inputs for the pots (except Waveform)
- Rotary switches for the Waveform and Multiplier
- PWM out, Clock out, Tap tempo in
telebiker
« Reply #1007 on: January 29, 2021, 07:18:11 PM »
CRAP where can I purchase an NSL-32   ???
 http://www.smallbearelec.com/Detail.bok?no=356  Small Bear Electronics is your best fiend ;)
There is my build
 For waveform and multiplier i using rotary switches instead of pots. That makes these functions a bit more understandabe. If someone interested - i found perfect rotary switches for that
http://eu.mouser.com/ProductDetail/ALPS/SRBV160803/?qs=sGAEpiMZZMvNbjZ2WlReYusHPuglWmCRYaNeyNyivdg%3d 6 position for multiplier
http://eu.mouser.com/ProductDetail/ALPS/SRBV181004/?qs=sGAEpiMZZMvNbjZ2WlReYusHPuglWmCRbZTSllc6Pt4%3d 8 position for waveform
All you need to do is build additional PCB
There is PCB's (open with Sprint Layot)
with trough hole resistors
NOT VERIFIED because i build second one version with SMD (8060 size) resistors
with SMD (8060)resistors
 VERIFIED
all PCB's is ready to trasfer
Cool build! BTW, I'm curious, how the illumination like this is done?
telebiker
« Reply #1009 on: January 30, 2021, 07:43:25 PM »
Thanks! Will try.
