Author Topic: beginner project help needed  (Read 11365 times)
Martz
« on: June 07, 2010, 09:18:24 PM »
I'm really new at this, but how can I know how much resistance as each resistor?
stratomaster15
« Reply #1 on: June 08, 2010, 05:16:01 PM »
One way is by reading the color bands on the resistors. Check out the wiki, I believe there's some helpful things on resistors there. Another way is by using a multimeter that measures ohms. I'd go with reading the bands though.
EDIT: This picture might be very helpful to you. http://www.boxofohms.com/ResistorColorCodes.jpg
« Last Edit: June 08, 2010, 05:20:45 PM by stratomaster15 »
Martz
« Reply #2 on: June 08, 2010, 05:49:28 PM »
Thank you so much.
Really helped me out. :]
Martz
« Reply #3 on: June 08, 2010, 07:12:35 PM »
Okay now wiring. I was wondering, did you guys send me two extra pieces or did I not do this right?
aron
« Reply #4 on: June 08, 2010, 07:17:02 PM »
Which two extra? What kind of components?
Martz
« Reply #5 on: June 08, 2010, 07:41:06 PM »
47uif
and a 47k resistor?
I really don't know anything about this stuff.
Martz
« Reply #6 on: June 08, 2010, 07:54:00 PM »
Never mind the 47uif. Its used on the back of the pot.
« Reply #7 on: June 08, 2010, 08:19:55 PM »
so you should have the 47k resistor going to ground as well yes!.there is only one.....look at the schematic again....
Martz
« Reply #8 on: June 08, 2010, 08:25:21 PM »
the one that goes with the led?
I guess I'm good then. :]
is this a special wire or I can take any? I need a bit more and I have a bit laying around in my tool box.
can I use it if its similar size?
« Reply #9 on: June 08, 2010, 08:28:03 PM »
no the 47k that goes with your circuit...look along the bottom line of the schematic...
p.s ...an led resistor will probably be a 4.7k...not 47k....
edit:..sorry have you got a kit or something?,...
Martz
« Reply #10 on: June 08, 2010, 08:30:13 PM »
Yeah I have it.
aron
« Reply #11 on: June 08, 2010, 08:32:14 PM »
The LED resistor is usually with the LED and the bezel.
aron
« Reply #12 on: June 08, 2010, 08:32:47 PM »
The 47K resistor is the bottom of the schematic - look to the left of the word boost:
Martz
« Reply #13 on: June 08, 2010, 08:34:53 PM »
thats the 5k pot?
aron
Re: beginner project help needed
« Reply #14 on: June 08, 2010, 08:35:58 PM »
To the left of the word boost. 47K.
Martz
« Reply #15 on: June 08, 2010, 08:38:13 PM »
Yeah I know where it is on the drawing. But physically, what is that piece next to the resistor?
I'm really sorry about this guys, I'm really trying to understand.
aron
« Reply #16 on: June 08, 2010, 08:41:00 PM »
What do you mean by this?
Martz
« Reply #17 on: June 08, 2010, 08:42:00 PM »
Okay that one I have in place. I have one left. Its a blue resistor.
With yellow purple black red and gold. Can't find that value. :/
aron
« Reply #18 on: June 08, 2010, 08:44:23 PM »
That sounds like the LED resistor. Was it tucked in with the LED inside the bezel?
Martz
« Reply #19 on: June 08, 2010, 08:45:47 PM »
It might have fell, Its not here now.
