Author Topic: Polished enclosure resistant to etching?  (Read 6545 times)
Johnny Lemonhead
« on: June 12, 2010, 10:46:37 AM »
I bought a pre-polished enclosure for etching, so I obviously didn't want to sand the surface and ruin the finish. After ironing the PnP and masking the sides, I started the etching process with ferric chloride as I did before with a regular home-sanded enclosure.
First I thought the ferric chloride-to-water-ratio was wrong because nothing happened for a long time, but after adding some more FC to the mix, I began to think the brushed aluminum might be etch resistant.
I looked closely at the parts where I retouched the design by scraping the surface with an x-acto knife during the masking process, and those did etch.
Does anyone have any experience etching these enclosures, or is it a known fact that they cannot be etched?
Thanks.
chi_boy
Re: Polished enclosure resistant to etching?
« Reply #1 on: June 12, 2010, 11:25:59 AM »
Are you sure it isn't clear coated?
"Great minds discuss ideas, average minds discuss events, small minds discuss people." Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
Johnny Lemonhead
« Reply #2 on: June 12, 2010, 12:15:29 PM »
Well, it only said "polished" when I ordered it and it didn't appear to have been coated. Felt like finely brushed, buffed aluminum.
nosamiam
« Reply #3 on: June 12, 2010, 12:47:28 PM »
I would guess it has been coated. There is a chemical that can be sprayed on bare aluminum (or it can be dipped in it) to prevent corrosion. It's what they use on polished rims for cars. It's visually undetectable. Maybe try paint thinner? Ultra-fine steel wool?
« Reply #4 on: June 12, 2010, 12:53:24 PM »
I think of this esoteric chemical as "lacquer". I'd try wiping it down with lacquer thinner, perhaps also acetone.
It is possible that it's coated with catalyzed urethane, but unlikely.
Johnny Lemonhead
« Reply #5 on: June 12, 2010, 01:02:36 PM »
Yeah, I will have to remove all the masking, sand it down and do the whole thing from scratch. Very annoying, especially because the higher price of the polished enclosure was supposed to spare me from applying time and elbow grease and not the opposite...
Anyone else planning on etching a pre-polished enclosure should take this to account.
Johnny Lemonhead
« Reply #6 on: June 12, 2010, 01:07:13 PM »
I now recall wiping the surface with acetone prior to ironing the PnP, so it's resistant to that as well. Does that make sense?
Thanks for the help.
« Reply #7 on: June 12, 2010, 01:27:49 PM »
Acetone doesn't remove lacquers all that well. There are several "lacquers". The specialize lacquer thinners are better. But sand/steel wool/polish is surer - if slower. Silicon carbide particles are a known solvent for all coatings softer than sapphire and diamond.
Don't laugh - vacuum deposited diamond coatings do exist.  :icon_exclaim:
« Last Edit: June 12, 2010, 01:30:07 PM by R.G. »
Johnny Lemonhead
« Reply #8 on: June 12, 2010, 05:03:35 PM »
Thanks for the information, R.G.
I have no choice but to sand it all down. The small grooves I made with the x-acto knife, during the touching-up of the masking, let way to the etchant that dug deep into the surface. I might also sand the sides as well for uniformity.
