Thanks for the replies. Yes this is the beginner project. It still isn't working, but here is what I have done:
I noticed the missing resistor not long after posting so thats fixed. The 100K resistor at the bottom of the board was going to ground instead of the power rail-fixed. I thought I had tested that the power rails were connected but when I tested again I got nothing, so that is fixed.
So, lots of mistakes. But this is my first build so I kind of expected this process.
I don't know what voltages I should be getting at the transistor. I'm assuming I test by touching the multimeter to ground and each one of the legs? When I did that I got 190mv at the emitter and collector and .8V at the base.
If I understand the audioprobe idea correctly it's just moving your positive output wire up the circuit till you get no sound? I tried that and I lose signal after the first .1uf cap. That first cap also is what knocks the voltage to .8V, is that right? It's from Small Bear and is listed as .1mf but I read that, that's how Small Bear labels their caps -'m' for micro instead of using that greek symbol that looks like a 'u'.
