Author Topic: Etched enclosures  (Read 912951 times)
Freppo
Re: Etched enclosures
« Reply #1440 on: May 28, 2014, 03:27:23 PM »
Hi there folks!
Here's my tries at etching... damn it's hard. :P
I can't how some people manage to do those super clean etches.
My third was a complete disaster..  :icon_cry: But the last one turned out good, finally!
I've had no luck with ferrit cloride. Tried Cautic Soda on the last one.
Followed the tutorial by DIY guitar effects and it turned out much better.  :icon_biggrin:
The Caustic Soda seemed to not eat away the toner as fast.
Cheers
/ Fredrik
Check out my building blog at www.parasitstudio.se
mikitz
« Reply #1441 on: May 28, 2014, 09:23:27 PM »
Hey Freppo, try different paper, that was the key for me anyway. Are you using inkjet photo paper with a laser printer? I found cheap dollar store inkjet photo paper worked the best... doesn't require any soaking at all.
Amateur Pedal Maker for myself and friends
Freppo
« Reply #1442 on: May 31, 2014, 06:58:53 AM »
Thanks for the tip! I  will try different papers
cheers / Freppo
Entropic_Dissonance
« Reply #1443 on: June 01, 2014, 04:55:44 AM »
Press and Peel Blue works the best, and works with Ferric Chloride, it's pricey but I could never get photo paper to transfer nicely. and this saves a lot of hassle and time. since sanding a failed transfer off get annoying after the eighth time.
spray paint the sides and inside of the box with a cheap flat black paint. (If you sanded it fine enough the paint will sand off with 600 grit with ease)
then use an enamel touch up paint to cover the rest of the exposed areas.
the inside can stay black, this will also prevent shorting.
« Reply #1444 on: June 01, 2014, 04:25:18 PM »
it really depends on what paper you have, ive used tesco's home brand glossy forever and it works flawlessly,
just let the box cool a little and peel off..no gunk, no fuss, .YMMV...
italianguy63
« Reply #1445 on: June 01, 2014, 04:38:57 PM »
I went through the whole paper hunt fiasco.  Best paper I found for the money is "HP Premium Presentation Paper 120g"
Product #CG988A
Used some today-- look at the etch/my post in the 1590A thread.  I'm defintely getting better at it.
MC
« Last Edit: June 01, 2014, 04:40:38 PM by italianguy63 »
« Reply #1446 on: June 02, 2014, 05:54:55 PM »
This is my first (and so far last) etching attempt. Either I'm really bad at this or I made it difficult by using a steel enclosure (footswitch from a Marshall amplifier). Or probably both. Either way, this is my Steel RAT.
« Last Edit: June 02, 2014, 06:00:43 PM by vigilante397 »
« Reply #1447 on: June 03, 2014, 03:35:05 AM »
. . . this is my Steel RAT.
Harry Harrison would've been proud.   :)
Liquitone
« Reply #1448 on: June 03, 2014, 05:05:44 AM »
That steel Rat looks great! I Used the exact same Marshall switch for a custom '19inch flipster and wanted to use metal letter stamps, but gave up because that steel is really tough. I bet it was difficult to etch as well?
« Reply #1449 on: June 03, 2014, 11:11:30 AM »
I guess I've never really tried etching aluminum so I have nothing to compare it to (aside from copper clad :icon_rolleyes:) but it definitely took several gallons of ferric with a few dragons heating and aggravating it for several years  :icon_eek:
Does aluminum etch easier than stainless steel? :icon_eek: WHY DIDN'T ANYONE TELL ME?
Liquitone
« Reply #1450 on: June 03, 2014, 12:07:45 PM »
I have never etched before so can't say for sure, but I wouldn't be surprised if aluminium will be much easier to etch.
Hexjibber
« Reply #1451 on: June 03, 2014, 04:04:44 PM »
Hey man, glad you had success with caustic soda and my tutorial! That last one looks great, hope to see more etches from you!
Cheers,
Graham
motvej
« Reply #1452 on: June 04, 2014, 03:29:12 AM »
latest mxr dist+ with clipping diodes mod
« Reply #1453 on: June 04, 2014, 03:30:53 AM »
sweet, love your style man... 8)
TG Flatline
« Reply #1454 on: June 04, 2014, 11:06:22 AM »
+1 Wicked etch!!
Hexjibber
« Reply #1455 on: June 04, 2014, 11:08:45 AM »
+1 Wicked etch!!
++1 (2?) Awesome job man! I think I was going to use that image on one of mine a while ago, old wood block prints are ideal for etches! :)
motvej
« Reply #1456 on: June 05, 2014, 11:51:13 AM »
I actually can not to get rid of it and find something new, maybe multicolor or smth different
But Albrecht Dürer is on of the most practical to etch)
italianguy63
« Reply #1457 on: June 05, 2014, 07:21:21 PM »
Which AD woodcut is that?  Familiar, but I can't remember.  Big fan.
MC
motvej
« Reply #1458 on: June 06, 2014, 02:11:37 AM »
MC
it's "apocalypse four horsemen"
the end is near!
Hexjibber
« Reply #1459 on: June 11, 2014, 07:46:55 PM »
My latest, it's a Super Duper 2 in 1
