...reminds me, that I forgot to mention what this actually is: It is a patchbox/Buffer Gateway to connect a thick multicore with the amplifier (Input, Send, Return, Footswitches for Reverb, Master Volume Boost (M.V.B.), Boost, Channel select). It contains 4 switchable Klon Buffers for each section of the signal path (Input Buffer, Buffer to Amp, Buffer from Send, Buffer to Return). Depending on the pedals on the pedalboard (buffered/True Bypass), multicore-length (home/stage) and guitar (active/passive), I change the buffers I use (I never use all four, though). Everything is color-coded (Multicore, Jacks on board and amp), so the setup is super easy. I am happy so far but am still looking for a better solution to splice the multicore.
