Author Topic: Etched enclosures  (Read 863591 times)
mfunky
  • Guest
Re: Etched enclosures
« Reply #1820 on: June 20, 2015, 05:23:47 AM »
Will look for that stuff!
italianguy63
« Reply #1821 on: June 20, 2015, 08:26:53 AM »
OK Guys... I will "unveil the artwork" on my Tychobrahe Octavia.
This is merely "Prototype#2"-- I did a quick acid etch to check the image spacing.  I have some slight issues... It should be slightly taller overall (note cramping at the knobs), and "Hex" should be lower... but, that is why I did the prototype, right!?!
Anyway-- this will ultimately be a my 1st laser etch...  Hence, why I am working on that K40 laser with Jimbo.  The enclosures are ordered from the powdercoater... and this should start real "production" units pretty soon.  MC
Elijah-Baley
« Reply #1822 on: June 20, 2015, 09:38:04 AM »
Nice work! :)
You know, I'm interesting in this Tycobrahe Octavia. Is there a substantial difference of volume between the octafuzz and fuzz?
Thanks! ;)
Cozybuilder
« Reply #1823 on: June 20, 2015, 09:48:53 AM »
Mark- Nice! This should be featured in a "top 100 effects pedals" article.
italianguy63
« Reply #1824 on: June 20, 2015, 10:18:03 AM »
Thanks Russ.  You are too kind...
I actually needed to build another to check out some other issues...  I have a color changing LED in it now, and I needed to determine where the filter cap needed to be added (to keep the "creepy" sound from happening) -- accomplished.  Also, the noise filtering on the power input is not working as designed.  I have to disconnect one of the grounds.  As you can see the LED is lit with no jack in the input jack.  (That is almost resolved now too)..  It is a very nice pedal though!!
Some other things worth noting.  "Tychobrahe Octavia" is trademarked.  So, it is "La Tunda".  It will merely be marketed as an "Octave Fuzz" pedal...
E.B..  I was playing with this early today, and NO, I did not notice a sizable volume difference.  BUT, I built this pedal with some GE's with a FV of about .39V.  The octave effect is minimal.  So, I need to pull them out and put in some with a FV of more like .33V to .35V...
No rest for the wicked.
MC
« Reply #1825 on: June 20, 2015, 10:39:56 AM »
nice work, itg. did you have to pay joan fonda by the hour for the sitting/posing? (or was it jane cusack?) nice footswitch placement.
is it too late for a "name Mark's pedal" competition? prizes?
« Reply #1826 on: June 20, 2015, 11:07:58 AM »
Makes a nice change from a sausage, duck.  BTW, who's Joan Fonda?  Is it Jane Fonda's Russian (bride) cousin?   ;)
greaser_au
« Reply #1827 on: June 20, 2015, 11:29:48 AM »
Never mind the pedal...   But, WOW, those prizes!!!!!!
david
italianguy63
« Reply #1828 on: June 20, 2015, 04:05:43 PM »
Elijah-Baley--
I put in different diodes-- big difference.  There is a change in volume (louder on Octave).  I guess that is something for you to "solve"-- as it is not so significant as to bother me...    MC
« Reply #1829 on: June 21, 2015, 06:40:10 AM »
Nice......for a second i thought she had a bad piles problem.. :D
rocket8810
« Reply #1830 on: June 21, 2015, 05:31:10 PM »
jesus marc. just looking at the enclosure, i can tell it was well worth the wait.
italianguy63
« Reply #1831 on: June 21, 2015, 05:42:02 PM »
Thanks-- hoping the "finished" final work is awesome..  The concept is good.
Groovenut
« Reply #1832 on: June 22, 2015, 06:35:02 PM »
mmmmmm yeeeesssssss......
Very nice!!!
You've got to love obsolete technology.....
lars-musik
« Reply #1833 on: June 23, 2015, 04:26:30 AM »
I have to double post this one . This is the first time I etched the labels for the jacks on the sides as well. A Rangemaster+Tonebender+Big Muff.
« Reply #1834 on: June 23, 2015, 04:32:16 AM »
Sweet build lars... 8)
« Reply #1835 on: June 23, 2015, 05:22:35 PM »
italianguy63
« Reply #1836 on: June 23, 2015, 07:28:34 PM »
Groovenut
« Reply #1837 on: June 24, 2015, 11:29:18 PM »
Here's another Taiseidou reverb I just finished. This one has a new version of the BTDR-3H that I modified to fit (the first version fit just fine but the manufacturer has made the outcase larger)
« Last Edit: June 25, 2015, 12:29:10 AM by Groovenut »
electrosonic
« Reply #1838 on: June 25, 2015, 02:41:14 PM »
This is going to be a lm741 diode clipped distortion (MXR style) with added tone control and clean blend.
I don't sand my enclosures - just an acetone cleaning and then press and peel. Not as pretty as some - but it is fine for me.
Andrew.
mfunky
  • Guest
« Reply #1839 on: June 25, 2015, 03:29:06 PM »
Looks great!
