Etched enclosures
Started by Johnny Lemonhead, July 15, 2010, 10:30:16 PM
stallik
Ok, only I'm in B&Q now . Yup, got it
Cool...its great stuff ...
stallik
Good timing. I've got a couple of DD's to prepare :)
Great...yeah i had 5 well rough 1590bbs....not now.
5 metres will last a long time.  Proper thick quality paper..
Have fun..
FiveseveN
Quick question... though this particular experiment took place more than a year ago.
I masked this Al enclosure using laser printer transfer and
> after testing a quick etch (permanent marker as resist) on the back of the cap, which I deemed fine, I used the following technique:
- scrubbed the surface with (plastic) abrasive sponge: needed for transfer;
- after trying my best to remove the paper fibers after transfer, I dabbed the surface with FeCl3 using a sponge, replenishing the reactant constantly.
- even after the time that would be sufficient for etching a PCB I did not observe any significant bevel, but the exposed surface looked like rust, even after a thorough rinse with water.
- sanded the surface with fine sandpaper (1000-ish) and some days after oiled it after I noticed rust forming again. It hasn't rusted thus far.
So this is what turned out: looks to me less like an etch and more like penetration of Fe atoms maybe?
I may have taken that picture enthusiastically before oiling.
What was the question? I've seen deep etches through simple immersion in FeCl3, and the sponge technique is supposed to be more aggressive, so what gives?! Not that I'm complaining, I like the way it turned out, but I'd like to understand the process for the sake of consistency.
Marcos - Munky
Just do the etching process over and over until you get the depth you want. Just remember to wait for the enclosure to cool down when it becames hot or the toner will start to be removed from the enclosure. Also, rinse with water from time to time to remove the metal that's been corroded. I usually do both things at the same time, when the enclosure starts to turn a little bit hot, I rinse it with water.
Btw, your etch looks amazing!
italianguy63
Quote from: Marcos - Munky on August 22, 2018, 07:55:52 PM
+1
You just have to develop a technique that works.  I use a mixture of HCL acid...  I found that 2 1/2 minutes is perfect.  So, I do 5 baths of 30 seconds each... between each bath, I rinse with water, and scrub off the "gunk" lightly with a toothbrush between dunks.
When I started, I found I was OVER-etching, and my etches looked dirty (and pitted).  It took some time to figure out where the sweet spot was.
italianguy63
#2408
My newest contraption---
Custom job/request.
It's a '67 PNP Dallas Arbiter Fuzz Face (detuned for bass)... feeding into a 3 band EQ... and then finally into a balance DI output.
Came out nice.
(Edit:  That old school 20uF cap looks like an M-80!)
MC
italianguy63
Quote from: bluebunny on August 31, 2018, 04:03:33 AM
Quote from: italianguy63 on August 30, 2018, 10:16:50 AM
Came out nice.
Sure did.   :icon_cool:
Thanks Marc!  A bit of a wiring nightmare (w/3 main boards).
The over-etch was purposely done.. guy wanted a gritty look to it..
MC
Which part is the crazy board that thinks it needs six trimmers?!?
Love the etch. Nice work.
T.
italianguy63
It is the EQ board.. adjusts the frequency and Q for each band.
Quote from: italianguy63 on September 01, 2018, 05:58:24 PM
I see! That's a seriously flexible little PCB then! Nice.
T.
italianguy63
#2414
Quote from: ElectricDruid on September 03, 2018, 03:43:08 PM
T.
Yeah--
It came from TH Custom Effects (Germany).  (Edit:  Note some errata in the build docs. if you build one)... Check the work/math.
It is a 3 band EQ-- and depending on what resistors and caps you use, you can set the frequency points and the Q width.
It was what I needed since I needed this pedal Lo-tuned for a bass player.
MC
MJ_Sound_Cubed
Wow, Some really good etchers out there :)
♫♪.ılılıll|̲̅̅●̲̅̅|̲̅̅=̲̅̅|̲̅̅●̲̅̅|llılılı.♫♪
MJ Sound Cubed
Community driven website to share your work at soundcubed.com
Marcos - Munky
16th build of 2018. Lastgasp Art Laboratories Rattle Crow. I remember this one got some interest back in time, but then it was kinda forgotten. Reverse etch based on the original artwork.
Marcos - Munky
17th build of 2018: Ugly Face, by Tim Escobedo. The sound of this one is just amazing.
Quote from: Marcos - Munky on September 19, 2018, 05:23:13 PM
17th build of 2018
I'm still hoping to get my third build of the year done.   :icon_razz:
Marcos - Munky
Well, if I had finished all the builds I've started, I'd been at least on the 30th build of 18 :icon_lol:. This year is being productive, but I'll take a good break after I finish some projects to clear my head a little bit and do other stuff. Maybe 25 it's a cool number.
