PT2399 inquiry
Started by ~arph, July 30, 2010, 09:01:20 AM
~arph
I was digging through the webs for info on the pt2399 and found an interesting lead. Yet unconfirmed.
Can someone verify this:  If you short pin 5 to ground. Do the echo's stop?
I'm trying to find out if pin 5 (clock output) is unbuffered or not.
If not.. we can connect a clock here and ignore pin 6. resulting in full linear control over the delay time.
JKowalski
I would expect it to be buffered.
But you could just put a low value resistor on it and figure out the impedance by seeing if the voltage is lowered.
Quote from: ~arph on July 30, 2010, 09:01:20 AM
I'm afraid not, other than adding a load of hiss nothing happens if you short pin 5 to ground.
Shame really that you can't directly control the clock, some of the other chips in the range let you, but I think they are obsolete now.
JKowalski
Isnt there only two chips in the line - a SPI one that only has like 16 different settable delay times and the PT2399?
I think that's all there is now, there used to be the PT2395 as seen here http://www.cgs.synth.net/modules/cgs44_ddb.html, that allows an external clock to be used. I seem to remember seeing on the Princeton site that they were stopping making this though so I've never bothered playing with it.
JKowalski
#5
Quote from: slacker on July 30, 2010, 01:23:24 PM
Ah ok,
I was thinking about the PT2396, totally different.
I feel like I remember seeing that for sale at futurlec a while back but I checked and it's not there (anymore?). Smallbear actually has them, 5$.
But yes, it is hard to find, expensive, and takes up massive board real estate.
