Author Topic: Why use the inverting input on the 386?  (Read 1302 times)
Top Top
« on: August 02, 2010, 06:38:53 PM »
I've noticed that in a number of the 386 amp designs, the 386's inverting input is used, but (if I remember correctly) in all of the designs in the datasheet, the non-inverting input is used.
What is the advantage of using the inverting input? Does it just make the layout easier?
brett
Re: Why use the inverting input on the 386?
« Reply #1 on: August 03, 2010, 03:17:31 AM »
Hi
Inverting stages can help with feedback (ie any "leakage" that finds its way back to an inverting input cancels rather than reinforces the signal).
Also, non-inverting stages are sometimes used where the input stage has high impedance (such as JFET op-amps).  Because the 386 has low input impedance, this advantage of non-iverting stages isn't there.
there might be other reasons too...
Brett Robinson
jasperoosthoek
« Reply #2 on: August 03, 2010, 05:03:09 AM »
Several years ago I built a little amp for a battery powered speaker. It has two lm386s, one connected in inverting mode the other in non-inverting mode. That way I created a bridge tied load amplifier. It worked perfectly. http://en.wikipedia.org/wiki/Bridge-tied_load
I don't know why people apparently favor the inverting input, both are possible.
[DIYStompbox user name]@hotmail.com
