I am experimenting with coupling the Taptation and the PT-80 onto a single PCB, and hope to make this project available soon via General Guitar Gadgets.
I have tested on the breadboard all the functional blocks I am going to use and am finishing the PCB. It will have some very interesting features and address some issues I have seen discussed on tap tempo pedals, one in particular how to go between the tap and knob settings.
With the amount of features, pots (5), and switches (5) it will need the 1590DD enclosure.
I still use the very first PT-80 for my pedal steel rig, designed and built in early 2002, hard to believe its been that long.
Scott Swartz
Hi Scott,
I have been using the PT80 for sevreal years on my pedalboard and it is one of my favourite delays. Great project, Thanks!
As you might have read I have been experimenting with the PT80/taptation combination a bit now and I think it would sure make a great project.
I have them both installed in a C type (119x93x56,5mm) enclosure wich is just slightly deeper then the regular BB type (119x93,5x34mm) that is mostly used by everyone. (sorry for using these enclosure names as I do not recall the regular hammond types at this moment).
My PT80 has an added effectsloop. I use 4 pots (delay time (wich is replaced by the taptation delay time), feedback, modulation depth and mix) and 4 switches (timescale, double time, pwm, effectsloop), 1 momentary tap tempo footswitch, 1 bypass footswitch and 3 leds (timescale, double tempo, bypass). I am sure that with a clever designed PCB it would fit in the BB enclosure
This way it works great and I can use most available options. I like switches for time scale and double tempo. I also considered a rotary switch for that but that would make certain time divisions harder accessible ( probably true the other way around too).
I have been playing with the idea of adding a second delay board that would have the base time going while the other board would have the time division. I guess I would need a second tatption for that but it would create a very strong delay pedal. Maybe that is something worth checking out.
I am curious how others are working with the taptation but untill now there are not many posters yet.
Thanks, Marc
