Author Topic: NEW PRODUCT: Taptation Tap Tempo controller  (Read 363131 times)
The Tone God
Re: NEW PRODUCT: Taptation Tap Tempo controller
« Reply #220 on: April 18, 2011, 05:01:36 PM »
I have two questions:
1) I can't find anywhere in the documentation showing which position of the scale switch is what. Like when it's open, which scale is it, when it is connected to Vcc, which scale, etc...
2) Also, I've notice some drift on my tempo between the repeats and the LED. I know the documentation says you will hear this with the repeats up high, but I'm getting this drift after about 3 repeats, which doesn't seem high to me...
1. As stated there is chart in the data sheet that explains each setting of the various input and their corresponding effect on the tempo output.
2. The input to the PT2399 is sensitive. In testing I found that even when handling the wire connected the circuit the time would go off this is why I encourage the connection to be as short as possible to reduce error. I do have the designs of a version that should reduce this problem but only so much time right now.
Andrew
served
« Reply #221 on: April 19, 2011, 09:16:33 AM »
I have a problem.
It works. LEDs blink and button works.
But: If I close the cover of the enclosure, it will stop. LEDs doesn't blink, or blink very very fast. Feels like shielding is killing it. What could be the problem? Rebote works, but taptation makes very fast repeats.
swinginguitar
« Reply #222 on: April 19, 2011, 10:37:33 AM »
Is it possible to use this in tandem with a pot for speed? IOW, you can tap tempo or adjust with a knob....would you need a rotary encoder of some kind?
Barcode80
« Reply #223 on: April 19, 2011, 09:25:00 PM »
This functionality is already there in the kit. The tap sets the tempo, or you can set it with the knob.
The Tone God
« Reply #224 on: April 20, 2011, 02:26:05 AM »
Sounds to me like somewhere a connection is shorting. Try opening the case slowly while running and see at what point the circuit comes to life.
The TapTation does all that for you with a standard pot. No need for an encoder.
Andrew
served
« Reply #225 on: April 20, 2011, 07:32:16 AM »
Hi.
Still. Cant figure out why it does what it does.
I built it on a vero. Cleaned the board with alcohol.
Used the schematic on the page 3 RevB
LEDs blink like insane but not with full power, kind of dull. If I connect the power, I get one normal full power blink and from there it goes insane and dull, but its not affecting the Delay itself.
Any ideas?
Caps are Ceramic.
Resistors are metal 1%
Wires are max 10cm long.
Used Delay time only.
« Last Edit: April 20, 2011, 08:17:21 AM by served »
The Tone God
« Reply #226 on: April 20, 2011, 03:54:31 PM »
If LEDs are blink dull and other random behaviour then you have bad connection(s). Recheck and measure everything.
Andrew
served
« Reply #227 on: April 21, 2011, 04:44:37 AM »
Thank you Andrew!
Its a good product and you are providing very good support!
Good luck to you!
My IC socket was faulty, corroded.
Barcode80
« Reply #228 on: April 21, 2011, 01:59:15 PM »
Andrew
Thanks again on this Andrew. I wanted to let you know I think the chart has the function of connecting to ground and the function of connecting to Vcc switched.
served
« Reply #229 on: April 24, 2011, 10:56:53 AM »
Still. I am getting the same problem again and again.
In somekind of state it just starts to blink. At first it works fine but after working few minutes, it starts to go mad.
Could you point out, which parts are the most sensitive. Maybe I am having somekind of interference problems. Its not some thing I can call out, it just happens. So a shielded cable of maybe the vero I am using has the lines too tightly together, so it starts to oscillate?
So the problem varies. Now it only blinks fast if I close the enclosure. (no wires are pressed the board sits still) Same happens with different other metal plates if I put them too close.
« Last Edit: April 24, 2011, 12:10:08 PM by served »
The Tone God
« Reply #230 on: April 28, 2011, 02:06:14 AM »
Routing that pin 6 wire is really important. Unsheilded, close as possible between the PT2399 and digital pot, try to keep it away from other signals especially ground.
Andrew
mhartington
« Reply #231 on: April 28, 2011, 09:55:37 AM »
just a simple question that has nothing to do with the actual construction of the taptation, but what are you all using for enclosures? It becoming a very tight fit for me and wanted to know what bigger enclosures people are using
sentimentalbob
« Reply #232 on: May 15, 2011, 06:38:28 PM »
How to calibrate taptation?
If taping temp by the metronome, LED blinking "in the metronome click". But repeats are faster then LED blinking
POT is 50kB
I tried with and without 1k resistor on 6pin.
I tried to connect trimpot to the 6pin of PT2399, but if I calibrate to temp 120
on other temps repeats are lost temp
au_loki
« Reply #233 on: June 02, 2011, 05:47:31 AM »
You have to remember to put your tongue out of the right hand side of your mouth while you tinker or it will never work.
Oh just wait - I am in the southern hemisphere so maybe it only works if your tongue is out the left side (you have got no hope if you live on the Equator).
Back to reality, there are a few variables involved here as we are using the PT2399 chip in a circuit that it really wasn't designed for.
While in years gone by it was a winner in the mass produced karaoke machine or surround sound equipment market where specific timing isn't required we have laid upon it expectations to perform perfectly in the precise tap tempo arena that we have forced it into.
The problem comes down to the actual internal tolerances of the much loved PT chip itself.
I encourage you to try a couple of different chips and keep the one that works the best or buy a DD7/DL4 etc.
Big thanks to TTG for coming up with this idea and seeing through.
Catch you later
au_loki
YouAre
« Reply #234 on: June 02, 2011, 09:33:44 AM »
A tongue in cheek joke about your tongue being in your cheek? I love it  ;D
bradfromtampa
« Reply #235 on: July 03, 2011, 09:33:50 PM »
sorry if this has been answered already, i think i've looked through all the posts....   can you add a tempo led to this?  meaning an led that will blink to the tempo.
The Tone God
« Reply #236 on: July 05, 2011, 02:10:12 AM »
There are two LED outputs. One spits out the tempo that was entered and the other spits out the tempo with the divider applied.
Andrew
bradfromtampa
« Reply #237 on: July 05, 2011, 07:24:52 PM »
Could i make a tap tempo pedal that would control 2 dd-5's with a tempo light?  If so, how would I go about doing this?  I'm a novice, again, sorry if it's been covered already.
The Tone God
« Reply #238 on: July 07, 2011, 03:01:12 AM »
I don't have a DD5 but I would assume it uses a momentary switch. I suppose you could but I think the issue would be that the LED would constantly be setting the tempo. You would need some kind of counter to trigger the DD5 for a number of pulses then stop. It can be done but it requires some extra logic to be built. Not the easiest thing to do.
Andrew
served
« Reply #239 on: July 07, 2011, 09:17:56 AM »
A question.
If I connect two bright LEDs to the circuit, it will start to click. Can I fix it, or i have to use other LEDs?
