Author Topic: "Little Angel" - Super Simple PT2399 Mini Chorus  (Read 560884 times)
blooze_man
  • Great Contributor!
  • Total likes: 1
  • Adrien - Anchorage, Alaska
Re: "Little Angel" - Super Simple PT2399 Mini Chorus
« Reply #240 on: September 10, 2010, 07:06:00 PM »
I wonder how this would sound if it had a tone control
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
clamup1
« Reply #241 on: September 10, 2010, 10:56:37 PM »
hey does the words on the LFO go toward the ic or away from it.
Taylor
  • Total likes: 67
  • The clean energy source of the future.
« Reply #242 on: September 10, 2010, 11:31:07 PM »
An LFO is not a part, it's a circuit with a number of parts that make it up. So what are you referring to when you say "LFO"? Are you talking about the thing with 3 legs and a metal tab on it? That is called a regulator, and you appear to have it in right.
clamup1
« Reply #243 on: September 11, 2010, 08:27:33 AM »
thats not my pic but i put it in that way. thanks
  • Total likes: 123
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
« Reply #244 on: September 11, 2010, 08:47:26 AM »
I'm gonna add a 'dark' pot for tone to the elite version - "Archangel"
@ clamup1: did you use a NE5532 dual opamp? The circuit values are set up to work with a NE5532. Other dual opamp type will give different results.
clamup1
« Reply #245 on: September 12, 2010, 12:45:42 PM »
yeah i used the 5532. i got everything in and its still didnt work. i get clean but no effect. ive seen 2 different ways to hook up 3pdt and cant get either one to work.
  • Total likes: 123
    • frequencycentral
« Reply #246 on: September 12, 2010, 01:13:39 PM »
Can you test the circuit away from the 3pdt? It may be your 2pdt wiring that's causing the problem. Maybe.
clamup1
« Reply #247 on: September 12, 2010, 02:49:48 PM »
my chips are facing the right way and i still have 8.29 on the ground. i had to buy a new solldering iron b/c the tip dissengrated so i was leaving huge solder bumps on the board. i think i have to either reetch a board or desolder and try again
Earthscum
« Reply #248 on: September 12, 2010, 02:53:46 PM »
clam: quick question... did you socket the IC's? If so, have you tried just swapping out IC's? There was a bad batch of (possibly counterfeit) PT's running around. I'm pretty sure that the normal DIY pedalbuilder sources are fine, I don't remember Steve or anyone saying that they came from their batches.
  • Total likes: 123
    • frequencycentral
« Reply #249 on: September 12, 2010, 03:03:17 PM »
Look for solder bridges anywhere where the (red) +9v trace is close to the (brown) ground trace. ie around C11, D1, R8, R9.
Earthscum
« Reply #250 on: September 12, 2010, 03:26:22 PM »
Should we Keen clam and refer him to This Page:icon_twisted:
I blew out a TL072 and got a short through the chip. I kept getting my 9V on the ground, regular VR's where they were supposed to be. I about fried my PS, and probably would have if I didn't catch the smoke from melting plastic... heat sinks are GOOD!
clamup1
« Reply #251 on: September 12, 2010, 06:09:12 PM »
both ic's are in sockets. i have swapped both ic's. i got my ic's from small bear i dont think they would sell bad chips. ill check for solder bridges, it wouldnt surprise me
clamup1
« Reply #252 on: September 12, 2010, 07:17:48 PM »
hey i think i fgured it out. the diode is blown or not hooked up right. im getting 8.72 on the neg side of the diode. which accounts for why i have 8.72 on the ground. i didnt know you could blow diodes. i hope this works. ive been staring at this thing for an hour.
clamup1
« Reply #253 on: September 12, 2010, 07:38:32 PM »
well that didnt work. im getting almost the same mv thats coming off the end of the diode. i dont know what it is. i gotta study for a test. later
  • Total likes: 123
    • frequencycentral
« Reply #254 on: September 12, 2010, 08:02:13 PM »
Is the diode correctly oriented?
soggybag
« Reply #255 on: September 12, 2010, 11:53:51 PM »
I just built one of these for myself, from the layout here. I used a piece of perfboard, but followed the PCB layout.
Before adding any ICs I powered everything up and tested the voltage at the correct pins. Op-amp pin 8, 5V at the regulator and PT2399. Everything checked out. When I put the chips in I wasn't getting any oscillation. After a long "close" inspection I couldn't figure it out. Came back later for a quick look and see an obvious solder bridge. Fixed that and everything started working. Never under estimate the effect of taking a break on your productivity.
I haven't given it much of a test yet. First impressions seem to say that everything is working correctly. Sounds to me like the LFO has sort of a wobble to it. Like it's not quite a triangle. This seems to change as the speed and depth are adjusted. I'll have to test it some more.
I did sub the 100 ohm resistor from PT2399 Pin 6 to ground with 82 ohm, as this was the closest I had on hand. I figure this wouldn't make much difference? I'm thinking about adding 50K pot to ground at this resistor to get regular delay and chorusy sounds. I assume this should work.
« Last Edit: September 13, 2010, 12:01:51 AM by soggybag »
Earthscum
« Reply #256 on: September 13, 2010, 12:12:04 AM »
I'm starting to wonder if C11 (power filter cap) isn't bad? What typically happens to caps when they go bad?
I've had a cap that I suspected was blown and it read as a resistive short (aluminum electrolytic), but I don't know if that is typical behavior... I threw it away without an autopsy, but I'm guessing the dielectric  material melted and allowed the 'plates' to make contact.
clamup1
« Reply #257 on: September 13, 2010, 08:10:26 AM »
i have gone over the + rail and scraped all the melted plastic away from everything else. the diode is put in the same way as its in on the schem. i didnt check the cap. i did break both of my small drill bits so i had to use a 1/16 on the end where the pot, +,-, wires go. soldering those was fun. i also unhooked the switch and took out the ic's.
clamup1
« Reply #258 on: September 13, 2010, 10:51:20 AM »
 :icon_redface: im not gonna tell you what i did wrong but i got that fixed
now i get clean with ossilation, switch on have to turn my amp all the way up and only get a little bit of signal.
clamup1
« Reply #259 on: September 13, 2010, 04:28:23 PM »
i have a ? about how to hook up the jacks. im not at my home computer so i cant find the website but. does the board have to be grounded to the encloser and do the jacks have to be grounded to each other.
