So, the way that the 470K depth pot is wired on the Little Angel, (with lugs 2 & 3 connected and Lug 1 open) as the pot is turned CCW or down, does the resistance go UP or DOWN?
As you turn the pot "down" (CCW), the resistance goes up - to 470K ohms if you're using a 470K pot; to 100K if you're using a 100K pot. As you turn the pot "up" (CW), the resistance goes down to zero ohms - regardless of what value pot you are using. So simply replacing the 470K pot with a 100K pot (wired the same way - lugs 2 and 3), and using the full rotation, is exactly like using the top (CW) ~20% of the 470K pot.
The switch on my build is wired so that the resistance is either 470K (simulating having a 470K pot turned all the way down), or somewhere between 0 and 100K depending on the rotation of the pot.
