Author Topic: "Little Angel" - Super Simple PT2399 Mini Chorus  (Read 689242 times)
Poste
Re: "Little Angel" - Super Simple PT2399 Mini Chorus
« Reply #600 on: April 13, 2011, 01:48:54 AM »
Does the polarity protection diode need to be a 4007 can it be a 4001?
Thanks in advance
Taylor
  • Total likes: 79
  • The clean energy source of the future.
« Reply #601 on: April 13, 2011, 02:13:09 AM »
It can definitely be a 1n4001. Not sure why 4007 was chosen, probably was just the part that somebody had lying around. The only difference AFAIK is the amount of reverse voltage it can take, and the 4001 is good for 35 vRMS, which is more than it will ever see.
  • Total likes: 155
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
« Reply #602 on: April 13, 2011, 11:33:42 AM »
Yup!
funkyhead
« Reply #603 on: April 23, 2011, 11:50:06 AM »
Hi, I have made this circuit couple days ago but it doesn't work properly. There is some change in the signal but no effect. Only when i'm turning the depth pot sound is a bit modulated. I changed the resistor from pin6 of PT2399 to 1k an then to 4k7 and only I had one repeat and nothing else. I checked for short circuits and cold joints and didn;t find any. The chip as well as the op-amp are ok. Any idea what's the problem?
  • Total likes: 155
    • frequencycentral
« Reply #604 on: April 23, 2011, 12:36:53 PM »
If you're getting a single delay the PT2399 part of the circuit (ie the audio path) is working. Sounds like your LFO is not functioning to me.
ppaappoo
« Reply #605 on: April 23, 2011, 02:28:11 PM »
check the speed pot connection.
disconnect the depth pot an place a led to see if the lfo works
funkyhead
« Reply #606 on: April 24, 2011, 08:19:32 AM »
I think you are right. Pots are fine. The led connected instead of depth pot didn't do a siongle thing. I kinda know what the LFO is but how to make it work? I think i'll use the osciloscope and if it'll showa that the LFO's not working I don't know what to do next.
egasimus
« Reply #607 on: April 27, 2011, 06:49:03 AM »
Hey, I'm planning to build this soon with Earthscum's mods. Can the circuit, however, work with line levels? After I saw ADT mentioned in this thread, I'm tempted to use it as an insert on vocals :icon_smile:
  • Total likes: 155
    • frequencycentral
« Reply #608 on: April 28, 2011, 03:04:06 PM »
So I've been through my stash of PT2399 and found one that locks up intermittently. So I'm gonna forego the wedding tomorrow (  :o  ) and add the Pin 6 Fix kludge:
The fix itself is verified but I wanna try it for myself. The layout above should sit in my 1590A Angel between the 9mm pots and the main PCB, I'm gonna bend C1 over to make the whole kludge flat. I guess also I should do a new layout incorporating the fix sometime. I think I could squeeze it so it's still a 1590A-able layout, or just 'spread out' so it's only 1590B-able. What do people think?
Govmnt_Lacky
« Reply #609 on: April 28, 2011, 03:16:54 PM »
I thought the lock-up fix was solved with a 1K resistor off of Pin 6 of the 2399 chip instead of the 100R.  ???
Then again, I cannot see the picture in your post so.....  ::)
for an amount of ‘up to and including my life.’
  • Total likes: 155
    • frequencycentral
« Reply #610 on: April 28, 2011, 03:24:43 PM »
Apparently the '1k at pin 6' fix works for some PT2399............and other PT2399 will work fine with 100R at pin 6. But mictester's pin 6 fix will make each and every little PT2399 in the whole wide world work in the Little Angel. With the added benefit that the resistance to ground from pin 6 is about 100R, which IMO is preferable to the extra latency that the '1k at pin 6' fix adds.
GodSaveMetal
  • Great Contributor!
  • Total likes: 4
  • Roberto Barrios Thays Lima -Perú
« Reply #611 on: April 28, 2011, 03:55:56 PM »
Thanks for the UNIVERSAL FIX 2399!!! it is a great idea!! I have some Pt's that don't fix for the LITTLE ANGEL chorus!!! I will tried this for every Pt's!!! great!!!
egasimus
« Reply #612 on: April 29, 2011, 07:43:42 AM »
Rick - why don't you use vertically mounted resistors and diode? They would still be shorter than the electrolytic, anyway, unless it's one of those extra-tiny ones.
I've also been wondering about this - I want to build the Little Angel with Earthscum's 10k+10R mod at pin 6 - can this be combined with the anti-lockup mod?
  • Total likes: 155
    • frequencycentral
« Reply #613 on: April 29, 2011, 07:50:46 AM »
Risk of grounding against the enclosure in 1590A builds. The electrolylics are layed out so as to be bent over and layed flat.
Sure, just add the pot in series between the 47R and pin 6.
funkyhead
« Reply #614 on: April 29, 2011, 09:54:00 AM »
Halleluyah! Heil to the PT2399 unlocker! Heil to Frequencycentral! You're the greatest  :icon_biggrin:
cgibsong002
« Reply #615 on: May 10, 2011, 01:17:05 AM »
Hey guys... desperate need of some quick help here. I'm actually building this as a project for my circuits class. We weren't allowed to do pcb so I used the bolstad vero layout. Bypass is good, and when switched on it sounds basically exactly the same as bypass, with a touch more noise. It seems as if my switch or something were shorted from input to output but i dunno. What is this 'lock-up'? I tried reading through all the pages about the pt2399 locking up but i haven't a clue what that means. would that cause a problem like i'm having? i originally used the 47 ohm that it called for, and then switched to a 470 ohm since i don't have a 1k. I figured I'd ask here before keep switching out resistors.
here are my values
5532 (Volts)
1.   5.19
2.   4.92
3.   4.79
4.   0
5.   3.65
6.   3.09
7.   8.80
8.   9.46
PT2399
1.   5.02
2.   2.40
3.   0
4.   0
5.   1.30
6.   2.36
7.   .55
8.   .69
9.-16. 2.42
2N3904
C. 1.69
B. 0.00
E. 0.00
Regulator
9.46 =IN  5.02=Out
Govmnt_Lacky
« Reply #616 on: May 10, 2011, 11:08:02 AM »
Hey guys... desperate need of some quick help here. I'm actually building this as a project for my circuits class. We weren't allowed to do pcb so I used the bolstad vero layout. Bypass is good, and when switched on it sounds basically exactly the same as bypass, with a touch more noise. It seems as if my switch or something were shorted from input to output but i dunno. What is this 'lock-up'? I tried reading through all the pages about the pt2399 locking up but i haven't a clue what that means. would that cause a problem like i'm having? i originally used the 47 ohm that it called for, and then switched to a 470 ohm since i don't have a 1k. I figured I'd ask here before keep switching out resistors.here are my values
5532 (Volts)
1.   5.19
2.   4.92
3.   4.79
4.   0
5.   3.65
6.   3.09
7.   8.80
8.   9.46
PT2399
1.   5.02
2.   2.40
3.   0
4.   0
5.   1.30
6.   2.36
7.   .55
8.   .69
9.-16. 2.42
2N3904
C. 1.69
B. 0.00
E. 0.00
Regulator
9.46 =IN  5.02=Out
Try the 1K resistor. If that does not work, then you may want to try a different 2399 chip.
Good Luck  ;D
cgibsong002
« Reply #617 on: May 10, 2011, 02:13:04 PM »
didn't have a 1K so soldered two 480's in series... figured that was close enough (unless there's some magic number about the 1K mark). still nothing. tried two other different pt2399's... still nothing. tried a different power source, nothing..
wth??
Govmnt_Lacky
« Reply #618 on: May 10, 2011, 02:43:49 PM »
wth??
Can you post a link to the layout you are using?
I don't remember a 3904 being in Rick's circuit  ???
Also, I think that at least helf of your LFO should be wobbling and it is not by looking at your readings.
  • Total likes: 155
    • frequencycentral
« Reply #619 on: May 10, 2011, 02:59:42 PM »
He's using Sabro's vero. Sabro updated it with the 3904 based Pin 6 Fix.
http://www.sabrodesign.com/wp-content/uploads/2011/04/LittleAngelRev1.gif
+1, there should not be static voltages on pins 5, 6 and 7 of the NE5532. That's your problem.
I posted these voltages earlier in the thread. Note the voltages of the LFO part of the NE5532. By the way, the vero uses the 'other side' of the NE5532 for the LFO to the PCB version I built.
 NE5532
1:  0.13  to   4.9
2:  2.9    to   3.2
3:  2.7    to   3.1
4:  0v
5:  4.79
6.  4.9
7:  5.14
8:  9
PT2399
1:  5
2:  2.38   to   2.42
3:  0
4:  0
5:  2.75
6:  0.61
7:  0.88
8:  0.88
9 through to 16:  2.41 (slight movement)
« Last Edit: May 10, 2011, 03:18:42 PM by frequencycentral »
