hey hey.
So my L.A.'s been sitting halfway built for far too long now [along with (no joke) 13other pedals
Last package of parts arrived today thou, gonna head out and fetch em tomorrow and start finishing the projects.
So went through the thread again and as usual the info is all over the place and spread around.
Quote's below from what I reccon is the only needed info. To help next random person from reading through the
whole thread again for the X'th time.
I dont remember now but can posts here on the forum be edited "forever" ? so the first post easily can be updated
with the newest version of the schem / layouts avalible etc? that might [if possible] be a good thiing to do
From what I can tell the pin 6 fix still is no unilateral successful fix?
the PT2399's acting somewhat different and reports beeing all over the place as to why and when it looks up.
But.. it does help thou?
[I got a few of em to try with (in a couple of other delay pedals) so hope Ill find one who works, just curious mostly]
Pin 6 fix - Is this what Merlin was describing?
I guess so, sort of anyway, check quote's below.
So is there an updated schematic with these fixes...?
If so I might do an Onboard Pot 1590B with room for battery PCB...
Schematic for the Birthday Edition:
Well I was gonna save this as a surprise for LA's 1st birthday in August, but........
I wanted to keep it 1590A-able, but also add good things like the Pin 6 Fix and a seperate vref for the audio path. Here's the lowdown:
- Pin 6 Fix: D1/C16/Q2/R21/R22
I did add a little Pin 6 Fix subcircuit to a PT2399 that I know won't work without. It still has issues, but I think raising R22 to 100R and C16 to 47uF will sort it - Audio vref: R23/R24/C17 - suggested by merlinb as a way to reduce noise dumped into the older version's 5v vref supply by the PT2399
- C4 changed to 3.3nF - might be a bit darker but will be less hissy
As it's planned to be 1590A-able, hopefully all the electro caps should be able to be bend over 900 to lie flat against the PCB. C16 might be the trickiest.
I PM'ed this layout last week to a couple of people who expressed interest in verifying it, so you never know, it could be verified within a day or so. The layout does need a little tidy up, as I notice the pad sizes are not all the same size.
mictester over at the other place has developed a little sub-circuit to prevent the PT2399 from locking up:
"The PT2399 datasheet warns about having a low value resistor from pin 6 to ground during the power-on reset that the IC does automatically. The reset lasts 400 ms. I keep pin 6 with a higher value resistor for longer than the reset period. I tried it, and the three ICs I tried it with did not lock up. With the 2N3904 I used, the delay was pretty much identical to that from a 100R resistor. "
It would appear to be verfied twice. Should solve people's problems with some PT2399 not liking this circuit.
