The chip socket for the pt2399 is placed the wrong way round. The little semi circular notch should be on the left side. This is only to indicate which way round the chip should be inserted but if you haven't got that in the right way.....
Having said that, I see in a previous picture that you have the chip inserted correctly but it's worth checking
To be honest, this is the first time I notice that notch! LOL! Nothing like the bliss of ignorance, right? But the chip I did insert the right way, so I do not think that is the cause.
As for the voltage, I took out my trusty multi-meter, and went to check resistances... Got some surprises. Here's the resistor list with what should be in and what I measured:
Listed Value Measured Value
R1 68K 66.6K
R2 10K 9.53K
R3 10K 9.84K
R4 10K 9.80K
R5 10K 9.79K
R6 10K 9.77K
R7 330K 321K
R8 47K
318K
R9 100K
39.7KR10 220K Did not get a measurement
R11 220K 212K
R12 4.7K 4.6K
R13 33K
66.6KR14 100K 97.8K
R15 1M
2.09MR16 470K 462K
R17 10K 9.79K
R18 10K 9.80K
R19 1M Did not get a measurement
R20 10K 9.79K
R21 2.2K 2.18K
R22 100 98.8
R23 10K 9.20K
R24 10K 9.32K
The ones that have no measure is because I was getting no indication on the multi-meter. Correct me if I am wrong, but:
47K = Yellow-Violet-Orange
100K = Brown-Black-Yellow
Is this right? If so, I got the right resistors in place for R8 and R9, right?
I did notice that the 1M resistors I accidentally put 2.2M resistors, but I also noticed my 2,2M resistors have resistance all over the place (from 700K to 3M!). I also have the wrong resistor for R13, so I have to swap out 3 resistors and see what's up with the other 2. Does this sound about right?
