Thanks for the link, EBK.
I decided to start fresh. I will also make the holes smaller on the PCB. I used a 1/32 bit, but I think I will move to a 1/64 bit, as I find the holes are a little too big for this purpose, and that makes getting a proper solder joint right more difficult. I mai also get a soldering iron with a better tip; the one I have is a bit hard to work with!
As for solder bridges, before the "fix" I checked with the multimeter for continuity, and there was none, and except for the bad solder at the 2399 input, the rest of the voltages seemed OK. After the fix, I could not find any solder bridges, but I am sure at least one is there, as the voltage was wrong at many places.
As for the OpAmp, is there any issues with the switch?
Felipe
