Author Topic: "Little Angel" - Super Simple PT2399 Mini Chorus  (Read 533612 times)
Thomeeque
« Reply #20 on: August 09, 2010, 10:56:37 AM »
http://dl.dropbox.com/u/967492/Little%20Angel%20Demo.mp3
 Oh, that sounds promissing*! And I'd say that delay time is pretty short actually (just short enough for proper chorus)! Please, measure it if you have a minute.. Thanks a lot! T.
*to be specific: I miss slower speed and at the slowest speed on the demo I'd say modulation sweep is not ideal**..
**EDIT2: Maybe just increasing of the LFO -> Vref decoupling cap value (10uF on the schemo) would help it.
« Last Edit: August 09, 2010, 11:07:47 AM by Thomeeque »
Brymus
  • Total likes: 1
  • Bryan G. - Somewhere in the Mohave Desert USA
« Reply #21 on: August 09, 2010, 10:57:05 AM »
Whats your voltage out the 7805 ?
I have everything except that to try this...
Also hows the volume ?
I noticed no volume pot is it more than unity ?
I'm no EE or even a tech,just a monkey with a soldering iron that can read,and follow instructions. ;D
My now defunct band http://www.facebook.com/TheZedLeppelinExperience
~arph
« Reply #22 on: August 09, 2010, 11:02:25 AM »
I'm going to try this tonight with my favorite sine LFO..
EDIT: The 7805 puts out 5V
« Last Edit: August 09, 2010, 11:03:59 AM by ~arph »
~arph
« Reply #23 on: August 09, 2010, 11:05:58 AM »
By the way, you do realize a lot of boutique builders will now start modulating pin two right?  :icon_mrgreen:
No relation between voltage and delay time by any chance I suppose?
  • Total likes: 119
    • frequencycentral
« Reply #24 on: August 09, 2010, 11:07:04 AM »
It has more of a vibe feel to it.. come to think of it.. how does it vibe without the clean mixed in?
Wet only, a little latency is discernable when playing: http://dl.dropbox.com/u/967492/Little%20Angel%20Wet%20Only.mp3
Sounds great! Is the sound at 0:11 (the first time the effect is used) at the slowest speed?
Wet/dry mix, slowest speed, maximum depth, though easy to tweak for even slower and deeper: http://dl.dropbox.com/u/967492/Little%20Angel%20Slowest%20Speed.mp3
Voltage out of 78L05 is er, 5 volts. Unity gain. I tried a mix pot earlier in the experiment but it screwed with the unity, so I dropped it and went for fixed resistors.
They will have to ask my permission first surely?  :D
« Last Edit: August 09, 2010, 11:08:49 AM by frequencycentral »
Questo Ŕ il fiore del partigiano morto per la libertÓ!
Renegadrian
« Reply #25 on: August 09, 2010, 11:42:00 AM »
Nice clips, Rick!!! I have to try it soon!!! (hopefully in September...)
Slade
« Reply #26 on: August 09, 2010, 12:03:33 PM »
Genius work, you have just released another simple (beginner) chorus for this world. Simple design and sounds fantastic, almost like if you were young.
12Bass
« Reply #27 on: August 09, 2010, 12:12:13 PM »
Cool!  I'm also curious to know the delay time.
« Reply #28 on: August 09, 2010, 12:47:14 PM »
Sounds good, I'll have to have a play with that. Presumably the modulation still works if you stick a resistor between pin 6 and ground, so this could also be used to modulate any PT2399 based delay.
mth5044
« Reply #29 on: August 09, 2010, 02:04:52 PM »
You could modulate Vref and delay time  :o :icon_eek:
tiges_ tendres
« Reply #30 on: August 09, 2010, 02:15:47 PM »
I had gotten a Belton Brick based delay/reverb to sound pseudo chorus-y by starving the voltage.  I didnt investigate further because if you starve it too far, the chip freaks out and makes random, awful noises.  It kind of made it sound like a Deluxe Memory Man.
There is no reason you couldnt do the same thing to those reverb modules, which probably are just a bunch of PT chips in the brick.
Try a little tenderness.
caress
« Reply #31 on: August 09, 2010, 08:24:46 PM »
exactly.  nice to know there's a super simple way to voltage control these...  great job, rick!   :icon_mrgreen:
« Reply #32 on: August 09, 2010, 08:32:53 PM »
That is frighteningly good for two chips.
Hides-His-Eyes
« Reply #33 on: August 10, 2010, 04:51:12 AM »
A new chapter in modulation pedals, I hope :)
Thomeeque
« Reply #34 on: August 10, 2010, 05:45:58 AM »
So I'm now waiting for you clever guys out there to suggest any improvements.......
 OK ;)
 It's just a quick draft adressing my previous notes mostly, consider at least non-inverting input buffer and "No DC" mod.
 About the LFO buffer - it would be maybe cool to adjust LFO out to work around 2.5V (~PT2399 Vref), then decoupling 10uF cap (which makes shape of sweep dependant on speed in IMO not very pleasant way) could be removed.
 T.
EDIT: GIF slightly updated (+"Placeholders for.."), you may need to refresh page..
« Last Edit: August 10, 2010, 05:55:00 AM by Thomeeque »
  • Total likes: 119
    • frequencycentral
« Reply #35 on: August 10, 2010, 06:34:06 AM »
Thank you Tomas! I will try these mods soon. I have already added the 'no DC on output' mod, as well as adding a 100R to ground from pin 6 instead of directly grounding it, on Arnoud's advice. Interesting that you suggest non-inverting input buffer, I was under the impression (perhaps mistakenly?) that the output of the PT is inverted, therefore assumed that the inverting buffer I lifted from the Rebote 2 was appropriate? It's important to be mixing in-phase signals here, so I'll try it and report back. As for the LFO, I'm going to have to experiment some more to get it wobbling either side of 2.5v, but yes it will be worthwhile as the 10uF coupling cap certainly does affect the waveform. I see you added LPF's similar to Rebote, probably a good idea. I am also considering adding a 'bright' pot/cap to ground from pin 14. Maybe I should also try adding the wet/dry blend pot back in now there is no DC there!
~arph
« Reply #36 on: August 10, 2010, 06:44:43 AM »
I've seen some different cap values for the 9 - 10 and 11 - 12  connections(  datasheet ).
I recall seeing a schematic that had a switchable parallel cap at the pin 9 -10 cap. I believe it was labelled  HP/LP. So that cap supposedly has influence on the bandwith.. I'm curious what different caps do there.
I'm interested in everything pt2399 related as there might be improvements to my 4xpt2399 series delay. (which I still plan to release here)
Thomeeque
« Reply #37 on: August 10, 2010, 07:49:23 AM »
Thank you Tomas!
 My pleasure! :)
 Was there audible difference? Did you measure delay times with 0 and 100R by any chance?
 Both in and out LPFs of PT2399 are inverting so at the output you should be back at the same polarity (if delay line itself does not change it of course - you could actually check it as a part of delay time measuring experiment :)).
 There should be no difference for effect itself - you take dry and wet path from the same point so phase at this point is not relevant. It can by only important for the "outside world" (rest of you setup) in some special circumstances (like processing signal splited for more amps) that phase of passing dry signal is not inverted.. it's sort of "good practise" I'd say..
 Btw. Rebote 2 inverts phase twice (at input and at output), so it's (-1)*(-1)=+1 again :)
 Btw2: Electric Mistress does not care ;)
 Yes, it is again case where proper filtering may be important for "outside world" in some special circumstances.
 Again, Electric Mistress does not care ;)
 Why not? :) Even the "wet/dry blend pot" is one of the features I have found useless on chorus (..and phaser ..and flanger) for me (when it's there I just set it 50:50)..
 T.
« Last Edit: August 10, 2010, 07:59:16 AM by Thomeeque »
  • Total likes: 119
    • frequencycentral
« Reply #38 on: August 10, 2010, 08:27:06 AM »
.....as well as adding a 100R to ground from pin 6 instead of directly grounding it, on Arnoud's advice.
Non that I could hear. I haven't done any measurements yet........
I'd agree with you there, I have no use for wet/dry mix pots, and leave them 50/50. But others may find it useful, so there will be extra pads on the PCB for that option.
cpm
« Reply #39 on: August 10, 2010, 09:43:14 AM »
if only we had a more detailed technical data on the PT2399...
