Hi Aron, How do I buildt the range control? do I just put evertything together and let it hang from the pot.
I remember the golden rule, and i know it will work, but will it not break easily?
Yes, you connect it on the pot. Let me know if you have questions about this. I can draw up a picture if you need help.
The box gives the circuit stability. Once it's boxed, no problem.
>What fet do you recommend for the millenium bypass? is the mill2 better than the 1? the 1 seems a lot easier..
I have used the mill. 1 with no problems. I never needed to try the 2. I used an MPF102 and J201 with success.
>What do you use to hold the board inside the box? I sure could use a clear and slow explanation on how to populate a box and how to drill it.
I use velcro like R.G. mentioned in his guitar effects FAQ. Other people have used standoffs.
I will work on the box instructions. It's pretty easy. R.G.'s FAQ goes through box issues.
