BOSS MT-2 Metal Zone
Started by Jaca, September 06, 2010, 02:05:57 PM
Jaca
Quote from: arma61 on September 24, 2010, 04:05:41 PM
I'm far to be an expert but looks like an "easy" shoot!
(any distortion)+palm muting+pinch harmonic+good techinc!!
let's wait Rob to chim in! I'm quite sure he can do that with a 386 ::) and some techic  :D  :D  :D  :D
Hi Armando!
I checked the pinch harmonic, vhen the guitar is squeal. Is it the first one second of the video, but after it sounds like a humbucker.
very funny armando and yep i'm going to 'chime' in...ha ha... :icon_wink:
armando is correct!....hi gainy,palmy, mutey, pinchy,...and good picking....chime chime chime chime chime......... :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
Jaca
Hi Rob!
Do You have a simply distorsion circuit with op amp and two clamping diode and no more?
nope!..
clipping diodes?...just stick 2 facing opposite on the out of an op amp i guess..!..try different ones...
look up hard clipping/ soft clipping...!..someone else might be able to help u with that though!. :)
im busy busy busy at the moment...got to build a little 1watt op amp/amp for some dude!.. :icon_rolleyes:
Jaca
Yes, i have this ciruit on my mt-2, but i don't have humbucker to check, what is the different between single coil, and humby on the diodes. I will upload a picture from single coil signal.
Jaca
Here is the pictures, upper is the input, lower is the signal on the diodes.
I would like to remove the short impulses, but would be interested in looking a humbucker signal in the diodes.
Rob, good work!  :) I've got your guitar tone, and then forced into my pedal.
Jaca
A bit off topic:
What is the difference between neck and bridge humbucker pickups? Can I exchange it?
Thx
Quote from: Jaca on September 30, 2010, 07:02:28 AM
A bit off topic:
Thx
i would think they are the same standard....its just the position of pickups that changes the tone...
to my knowledge.....you can always measure them with a dmm..see what ohms etc....
it may be different with custom guitars etc.....
edvard
At the neck position the strings swing a bit wider and therefore produce more signal.
Therefore, pickups specifically made for the neck position are slightly under-wound to compensate for the extra volume.
Also, the sound from the neck position has less harmonic content, so the sound is a little "mellower".
Jaca
Hi!
A bit offtopic, but I use my MT2:
Somebody can help my? I found in my memory a sound, but I don't know, which band play it. Maybe it's not the correct, but very closely:
http://soundcloud.com/bjaca/ezmiez
Thanks a lot!
